70 Pages V  1 2 3 > »
> Just another damned project thread, 914-6 3.2 conversion in GT dress-up
ConeDodger
post Apr 2 2011, 03:15 PM
Apex killer!
First of all, let me say this: let's not turn this into a 4 vs: 6 thread. I like them both and really don't give a damn about your position on this non-issue.
All the legal stuff out of the way, let's talk engine.
First of all, this project is well advanced. The engine is already together and the 20 minute cam run in has been done. But let's talk about how we got to that point first...
This motor is a 2432 Raby kit. It uses the LE200 heads and stock 2liter cylinders. The stroked crank is 84mm I believe so think of it as a super-stroker. It will run Jenvey throttle bodies and SDS injection. The EFI sensors I have chosen to use will be TPS, CHT, MAP, IAT, O2 in closed loop, and I think that is everything. Injectors are Ford Red Top. This motor requires quite a bit of engine block clearance so as they say, don't try this at home...
It took me about three trips down to Original Customs to put the engine together. I used McMark's shop so I could get his free advice which he of course charges me for, and I don't get distracted by wives wondering how much all of this costs. Plus Mark has an engine break-in stand that allows us to fire it out of the car and correct anything that might be wrong without having to pull an already installed motor.
Here is a dyno sheet of one of these motors that Jake actually built. I would expect that my result might be within 10% of his. :Insert fingers crossed smiley here:
ConeDodger
post Apr 2 2011, 03:16 PM
Apex killer!
ConeDodger
post Apr 2 2011, 03:17 PM
Apex killer!
Custom air cleaners using K&N filters designed by Jake Raby
ConeDodger
post Apr 2 2011, 03:20 PM
Apex killer!
This engine will be distributorless so this is a couple shots of the Original Customs Hall Sensor mount. Also notice, the crankcase vent that was custom built by Jeff Hines (sixnotfour). This is replacing the distributor and venting the crankcase.
Mike Bellis
post Apr 2 2011, 03:22 PM
Resident Electrician
This is a bad ass build! Rock on! (IMG:style_emoticons/default/aktion035.gif)
ConeDodger
post Apr 2 2011, 03:24 PM
Apex killer!
Here are some random shots of the engine as it goes together...
ConeDodger
post Apr 2 2011, 03:25 PM
Apex killer!
Here is a close-up of just how much spacer you need to run that much of a stroke. Pretty thick!!! (IMG:style_emoticons/default/smile.gif)
ConeDodger
post Apr 2 2011, 03:27 PM
Apex killer!
QUOTE(kg6dxn @ Apr 2 2011, 01:22 PM) *
Thanks Mike! I'm just the cook though... Jake was the chef and Mark is supervising the kitchen...
Mark has a video of the cam break in. Maybe he will post that here...
Dr Evil
post Apr 2 2011, 03:32 PM
Send me your transmission!
(IMG:style_emoticons/default/wub.gif) Say what you will, that is beautiful!
MDG
post Apr 2 2011, 03:36 PM
Wolf in wolf's clothing.
I think I'd be a vibrating mess waiting to drive it. Those chart numbers are amazing. And the yellow line for fuel . . . it doesn't use any (IMG:style_emoticons/default/unsure.gif)
Seriously, congratulations on this!! (IMG:style_emoticons/default/smilie_pokal.gif)
ConeDodger
post Apr 2 2011, 03:38 PM
Apex killer!
Some planned locations for SDS components are as follows: The SDS ECU with it's hideous gold anodizing will hide under the passenger seat along with the O2 Sensor control unit. The coil packs will be over on the driver side wall just aft of the relay board. Here is a pic of the vacuum manifold that will collect and smooth the vacuum impulses from the four vacuum vents on the ITB's. This of course will be connected to the MAP. That hideous Eagle will be face down... (IMG:style_emoticons/default/barf.gif) The CHT will be in the stock 2liter location and in fact, is the stock Bosch unit. The Intake Air Temperature Sensor will be located between the air cleaners and correct me if I am wrong Mark - on the passenger side? This will use one of McMark's Original Customs designed mounts which he has used on other peoples motors...
ConeDodger
post Apr 2 2011, 03:40 PM
Apex killer!
QUOTE(MDG @ Apr 2 2011, 01:36 PM) *
Mike, I think it is an often overlooked fact that Jake's creations run smoother, use less fuel and run cooler than stock. I'd guess Jake didn't record that parameter 'cause this thing will be thirsty!
I am very excited.
(IMG:style_emoticons/default/evilgrin.gif)
ConeDodger
post Apr 2 2011, 03:44 PM
Apex killer!
QUOTE(Dr Evil @ Apr 2 2011, 01:32 PM) *
Has anyone else noticed that the only people who have responded to this thread are named Mike? (IMG:style_emoticons/default/dry.gif)
Thanks Evil... As we say in science the rate limiting factor at this point is the custom harness being built by Jeff Bowlsby. The prevalent opinion on the SDS harness was 'cheesy' so Jeff is building a custom one. The plan was to have it done in January but Jeff has some issues personally and professionally right now that are making his life hell and holding the harness up...
post Apr 2 2011, 03:46 PM
(IMG:style_emoticons/default/aktion035.gif) Nice job, Sweeeeeeeeeeet. And seeing as how these things usually end up being a 50/50 deal, what did you have to buy her as an offset? (IMG:style_emoticons/default/lol-2.gif)
Madswede
post Apr 2 2011, 03:51 PM
Flat Out Driver
Very cool! (IMG:style_emoticons/default/shades.gif) And even tho I'll have a /6 in my teener, I love big /4's! Look no further than my beloved 968 - 3.0L /4 (inline of course) that I plan eventually to have turbocharged.
Even right now, though, it's around 240 hp naturally aspirated thanks to VarioCam. Once of the reasons I fell in love P-cars in the first place was 'cos they find replacements for cubic displacement ... like good engineering.
I'm now in awe of Jake Raby.
- Nelson
ConeDodger
Apex killer!
QUOTE(76-914 @ Apr 2 2011, 01:46 PM) *
(IMG:style_emoticons/default/sad.gif) It's looking like a Cayenne S... Thanks to that provocateur Eric Shea!
rick 918-S
post Apr 2 2011, 03:57 PM
Hey nice rack! -Celette
Are you planning on attending the WCR with it? (IMG:style_emoticons/default/drooley.gif) Very nice! You have some of the best of the best working on it too!
VaccaRabite
post Apr 2 2011, 04:02 PM
En Garde!
This fills my "coolest thing of the day" slot!
What are you going to do for exhaust? I kinda doubt you are going to be able to use the usual suspects with that much extra space under the cylinders.
Zach
ConeDodger
post Apr 2 2011, 04:03 PM
Apex killer!
QUOTE(rick 918-S @ Apr 2 2011, 01:57 PM) *
I hope so...
MDG
QUOTE(ConeDodger @ Apr 2 2011, 05:44 PM) *
(IMG:style_emoticons/default/laugh.gif) We move in packs . . .
4 User(s) are reading this topic (2 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 19th July 2026 - 04:02 PM
