trojanhorsepower |
Senior Member ![]() ![]() ![]() Group: Members Posts: 895 Joined: 21-September 03 From: Marion, NC Member No.: 1,179 Region Association: None ![]() |
Hi All
After finishing my rotisserie I am finally getting back to actual car work (started in 03). I am redoing what I did in the past (made a mess of it) and hopefully moving on from there. Doug has is helping me with the restoration, so hopefully we can make some actual progress. The entire passenger side of my car is pretty rotten so we have our work cut out for us. I got the good part of the long cut out so when Doug gets here maybe we can start filling in the gaps. In this pic I have cut out the outside long bit. 10/1/15: Joined in the build off challenge! Attached image(s) ![]() |
dlee6204 |
Howdy ![]() ![]() ![]() ![]() Group: Members Posts: 2,162 Joined: 30-April 06 From: Burnsville, NC Member No.: 5,956 ![]() |
MMM...Rust (IMG:style_emoticons/default/chowtime.gif)
trojanhorsepower |
At this point I was afraid that there was not enough metal to really support the car suspended from the rotisserie, so my lift to the rescue. Now I feel better about cutting out more metal. Hopefully when Doug gets here I will have things ready to go so we can make some real progress.
trojanhorsepower |
I have an old Restoration Design? patch panel for the lower inside firewall. It is basically flat. The original has a dimple as does the current Restoration Designs panel. What is the dimple for?
rick 918-S |
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,038 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region ![]() ![]() ![]() |
The dimple actually touches the outside panel. That gets spot welded to add strength to the box the inner and outer panel are forming. Does that make sense?
trojanhorsepower |
Thanks Rick,
That makes sense. So I need to make a part to weld between the inner and outer firewall parts since min patch does not have the dimple. |
dlee6204 |
trojanhorsepower |
That would be great Doug. The outer section is bad to. The lower inch or so is gone and the part under the seam sealer around the heater tube is also gone. I also found some rust on the engine mount.
Attached thumbnail(s) ![]() ![]() |
trojanhorsepower |
Did a little work to boost confidence. It did not come out great, but it is much better than before.
Attached image(s) ![]() ![]() ![]() ![]() ![]() ![]() |
rick 918-S |
Thanks Rick, That makes sense. So I need to make a part to weld between the inner and outer firewall parts since min patch does not have the dimple. I'm having second thoughts about what I told you. If I can get a look at one of my cars I can remind myself about that pocket. Could be what I told you. (IMG:style_emoticons/default/screwy.gif) |
Douglas Miller |
Newbie ![]() Group: Members Posts: 1 Joined: 17-November 13 From: Roanoke Rapids NC Member No.: 16,661 Region Association: South East States ![]() |
Hi All After finishing my rotisserie I am finally getting back to actual car work (started in 03). I am redoing what I did in the past (made a mess of it) and hopefully moving on from there. Doug has is helping me with the restoration, so hopefully we can make some actual progress. The entire passenger side of my car is pretty rotten so we have our work cut out for us. I got the good part of the long cut out so when Doug gets here maybe we can start filling in the gaps. In this pic I have cut out the outside long bit. Sweet! Kids are ready to test drive! |
trojanhorsepower |
Hi Doug,
Glad to see you here. Don't hang out too long or you will have to learn to weld! Some mean person suggested that all the recent effort was so I could have the car ready as a collage graduation present for Hugh. Personally I did not think that was funny.... well maybe a little. |
trojanhorsepower |
Tackled another little spot tonight. I am not quite finished, but it looks better than the rusty holes.
Attached image(s) ![]() ![]() ![]() ![]() ![]() |
trojanhorsepower |
Plugged the antenna hole.
Attached image(s) ![]() ![]() ![]() ![]() |
trojanhorsepower |
Doug Leehr came out today and we got right to work. Doug and I have been busy cutting out the cancer. First we did a little bracing.
Attached image(s) ![]() ![]() |
trojanhorsepower |
Next we started cutting. First the motor mount had to come out.
trojanhorsepower |
Then we cut a patch panel to weld in after we clean up the rust.
trojanhorsepower |
Lastly we cut out the rest of the rust. In this section. And started to test fit patch panels.
trojanhorsepower |
Doug and I worked like elves today. While I did some cleaning Doug whipped up a curvy inner long bit.
trojanhorsepower |
We got that part tacked in and cut out the rest of the lower inner long, and tacked in new metal.
Lo-Fi Version | Time is now: 30th July 2025 - 03:07 PM |
