20 Pages V  1 2 3 > »
> Just another Factory 6 being fixed up
Luke M
post Oct 23 2015, 12:26 PM
Well it's gotten to be that time finally. I've been collecting parts to do the repair on my 914-6 and now the work starts. The main issue is the hell hole/inner engine long, inner pass long, pass inner rocker panels are rusted out. The last part I was trying to source seams to be NLA. I sourced most of the parts from the good guys at Restoration Design. I received my order today for the last batch of things. Based on a few threads that I've looked over the outer shell to the inner engine long is currently not being made by RD. A few guys have made their own which looks like a real pain in the rear to do. I laid out all the new metal to see how things lined up. By the looks of things it will need some fine tuning to mate things properly. Before I start cutting into the chassis I'll build a few braces to keep things true.
Time for the pics...
Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image
stevegm
post Oct 23 2015, 02:14 PM
(IMG:style_emoticons/default/aktion035.gif) (IMG:style_emoticons/default/popcorn[1].gif)
wndsnd
post Oct 23 2015, 02:20 PM
You wanted a horse, but got a goat. Nobody wants a goat....
Is that the car that Kirk sold?
Mueller
post Oct 23 2015, 02:36 PM
914 Freak!
Good luck...I hope mine isn't as bad once I start digging into it!
post Oct 23 2015, 03:05 PM
Excellent. It looks like you have matters well in hand. Keep the pictures coming. (IMG:style_emoticons/default/popcorn[1].gif)
Luke M
post Oct 23 2015, 03:20 PM
QUOTE(wndsnd @ Oct 23 2015, 01:20 PM) *
Nope.. I've owned this car going on 6 years now.
Purchased it from a local guy that didn't want to deal with fixing it. It was parked in a garage after the engine locked up and sat there from 1983 to 2009.
wndsnd
post Oct 23 2015, 03:31 PM
Big project for sure, but the fact that it is on a rotiserrie, should make it manageable. Measure twice, cut once. Enjoy.
rick 918-S
post Oct 23 2015, 03:41 PM
Hey nice rack! -Celette
Nice. (IMG:style_emoticons/default/popcorn[1].gif)
Kansas 914
post Oct 23 2015, 03:53 PM
Worth saving for sure.
Krieger
post Oct 23 2015, 05:10 PM
Yea!
Luke M
post Feb 20 2018, 11:12 AM
Well after nearly three years of searching for a NOS right long I was able to source and buy one. Probably the last one in the US that's for sale ( watch now two will pop up for sale ). I should have it in my hands by late Weds and will post pics once it's here. So with that said, I have a few questions on how to tackle this job.
I know Kent replaced the drivers side of Jim's 6 seen here :
http://www.914world.com/bbs2/index.php?sho...4443&st=100
I see Kent has made a jig to align things which I also made.
If you see this Kent how did you attach the rear most section to the rear trunk/shock tower area? Did you weld from the inside as well as the outer portions?
I plan to brace the living heck out of the chassis prior to cutting into it.
Any area worth more bracing then others? I plan on checking the door gaps and all of the specs prior to/while welding in place.
Stay tuned...
bbrock
post Feb 20 2018, 11:32 AM
Yeah Man! (IMG:style_emoticons/default/aktion035.gif) A lot of work, but also very satisfying. Looks like you've already got a handle on it, but brace the doors very well with an adjustable brace so you can adjust your gaps prior to and during welding. Once a long comes off, you'll be amazed how rubbery the car becomes, and also how easy it is to dial in the gaps precisely. I'm looking forward to watching this.
rgalla9146
post Feb 20 2018, 02:37 PM
Hey Luke
Excellent !
Now's the time. Take it one day at a time. It'll get done.
Be careful.
Rory
bigkensteele
post Feb 20 2018, 05:30 PM
Major Member
Why did you decide not to use everything you pieced together above? (IMG:style_emoticons/default/confused24.gif) Looks like you had it well underway.
Luke M
post Feb 20 2018, 07:16 PM
QUOTE(bigkensteele @ Feb 20 2018, 04:30 PM) *
I wanted an NOS part for the repair to begin with. It's just hard to come by the pass side now a days. I found one and will be using it to make the repair. I will sell the other parts that I will not be using.
Luke M
post Feb 20 2018, 07:17 PM
QUOTE(rgalla9146 @ Feb 20 2018, 01:37 PM) *
Hey Luke
Excellent !
Be careful.
Rory
Hi Rory,
Yes, I'll be taking my time and making sure it gets done correctly .
Luke M
post Feb 21 2018, 12:29 PM
Look what showed up today... (IMG:style_emoticons/default/piratenanner.gif)
I'll be removing the 4 cyl mount as this is going into a factory 6.
I'll be posting it for sale once I remove it.
The pics of this rare NOS item.
rhodyguy
post Feb 21 2018, 12:37 PM
Chimp Sanctuary NW. Check it out.
WOW! Platinum.
post Feb 21 2018, 12:38 PM
David Billo
post Feb 21 2018, 04:34 PM
Region Association: Canada
Wow, did that come all welded together like that as one complete inner long, including the battery pylon?
3 User(s) are reading this topic (2 Guests and 1 Anonymous Users)
- Lo-Fi Version Time is now: 31st July 2026 - 03:43 PM
