1973 Porsche 914 - 6 conversion |
mmascari |
Oct 29 2024, 02:14 PM
Member Group: Members Posts: 322 Joined: 1-September 14 From: Concord, CA Member No.: 17,850 Region Association: None |
1973 914 2.0, converted to 911sc 3.0 engine (still have the original matching numbers 2.0 engine)
original silver, repainted in factory L96D. This car was built from the ground up, all parts are new or rebuilt. I have all the receipts for all the work and parts that went in to building the car. Invested over $50k. Body: straight shell with no rust. See pics of under car, longs, hell holes and engine compartment. Car was painted throughout including the trunks, interior, and engine compartment. The bumpers are painted black. Spoke Works LEDs Suspension: All components were removed, powder coated black, installed with all new bushings. The front suspension is from a 911 with Koni struts and Koni inserts. The rear still has KYB shocks with unkown springs, however, I have the Rebel racing coilover kit that will be included. Brakes: The front and rear calipers are Porsche Boxster calipers, painted red, using the rebel racing adapters. New rotors all the way around, including 1980s 911 Carrera rotors, cross drilled. Wheels: The wheels are new Maxilite 16x6 with new Kumho tires 205/55/16. Engine: 1979 911sc engine, completely rebuilt, with case apart. The engine has roughly 1,500 miles on it since rebuild. Everything was checked and rebuilt including the crankshaft, heads were rebuilt. The pistons are new JE 9:1 compression pistons and the camshafts are webcam RS cams. ARP Rod Bolts. Carrera oil fed chain tensioners. The intake is PMO 46mm carbs with proper configuration. The harness was built by Perry and adapted to work with MSD ignition and coil. The distributor is a 123 ignition distributor that works great with the carb setup. Recently spent over $3k at PPM Motorwork in Walnut Creek to dial in the engine timing and carb setup. The conversion parts were purchased from Patrick Motorsports, including oil tank, lines, front oil cooler, shroud, thermostat, oil catch, etc. Exhaust headers with M&K exhaust Battery and MSD ignition is mounted in the rear trunk. Gas tank was taken out of car and lined. New stainless fuel lines and new Pieburg front mounted fuel pump. Transmission: Stock 5speed rebuilt with new syncros, etc. Shifts amazing Interior: Dynamat installed, new carpet, mats. 911 Carrera tachometer, 911 oil pressure/temp guage. Stock 914 speedometer/odometer that works. New looking back pad. Dash is custom stiched. Things that need to be addressed: 1) The headlights pop up but the right headlights does not go down. 2) The fog lights do not work 3) The reverse/backup lights do not work 4) The windshield wiper motor is installed but not connected 5) No heating and ventilation is installed due to the headers Spare Parts: rear chrome bumper front air dam rear coilover kit heat/ventilation parts Matching sport seats I have owned the car for about 10 years. I live in Northern California now but the car is still registered in Oregon so I have an Oregon title. Never registered it in California. car just sits in my garage. I take it for a spin once a week that's about all. Selling car for my son's college fund. Let me know if you have questions. I have a lot of pictures. Asking $40k but open to offers. Mark Attached thumbnail(s) Attached image(s) |
mmascari |
Oct 29 2024, 02:20 PM
under
Attached thumbnail(s) |
mmascari |
rear
mmascari |
Oct 29 2024, 02:21 PM
trunk
mmascari |
Oct 29 2024, 02:22 PM
If you have Instagram search for scarimas914
I have some videos on it |
IronHillRestorations |
Oct 30 2024, 07:12 AM
I. I. R. C. Group: Members Posts: 6,768 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Someone is going to get a great deal on an awesome 914! GLWTS Mark!
rdgabert |
Oct 30 2024, 09:03 AM
Newbie Group: Members Posts: 14 Joined: 22-October 14 From: SD Member No.: 18,050 Region Association: Upper MidWest |
Hello mmascari,
I am interested in car and have PM'd you. Cheers, Robert |
Chris914n6 |
Oct 30 2024, 02:24 PM
Jackstands are my life. Group: Members Posts: 3,407 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
I'd say it's worth the 50k you've got into it.
mb911 |
Oct 30 2024, 05:15 PM
914 Guru Group: Members Posts: 7,213 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Great value. Just an FYI as the former owner of M&k the pictured exhaust does not resemble any of my designs nor the new owners design. That said it’s an excellent deal for someone that you could not replicate for that money.
Lo-Fi Version | Time is now: 1st November 2024 - 12:28 AM |
