CFR Firewall Shifter Bushing, Fasteners |
TargaToy |
Oct 30 2024, 04:09 PM
-NONSOLIS RADIOS SEDIOUIS FULMINA MITTO- Group: Members Posts: 696 Joined: 26-March 10 From: DelMarVa Peninsula Member No.: 11,509 Region Association: MidAtlantic Region |
I'm installing Chris Foley's firewall bushing which is a beautiful design.
Has anybody installed one using fasteners other than the sheet metal screws or pop rivets that came with the kit? I've been contemplating installing #10-24 riv-nuts after reading someone else's experience with either the screws or the rivets (I can't remember which) working loose over time. What's your experience? |
Dlee6205 |
Oct 30 2024, 04:54 PM
Member Group: Members Posts: 53 Joined: 9-December 22 From: Burnsville, NC Member No.: 27,017 Region Association: South East States |
I've installed a couple so far and always used the rivets... I've never had an issue.
Rivet nuts aren't a bad idea.... I suggest keeping it metric though. (IMG:style_emoticons/default/poke.gif) |
jim_hoyland |
Oct 30 2024, 05:06 PM
Get that VIN ? Group: Members Posts: 9,467 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Ric-nuts sound interesting, tell us what you decide. I have the CF bushing but haven’t installed it yet.
gereed75 |
Oct 30 2024, 05:50 PM
Senior Member Group: Members Posts: 1,299 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States |
I fabbed a little nut plate to put on the interior side. Was able to install it one man that way. Rib nuts should work also.
jim_hoyland |
Oct 30 2024, 06:12 PM
TargaToy |
Oct 30 2024, 06:49 PM
I've installed a couple so far and always used the rivets... I've never had an issue. Rivet nuts aren't a bad idea.... I suggest keeping it metric though. (IMG:style_emoticons/default/poke.gif) Please don't think that wasn't my first idea. (IMG:style_emoticons/default/biggrin.gif) The predrilled holes in the bushing housing are smaller than 6mm but fit #10-24 perfectly. I want a little more beef than 5mm bolts. Although I may open the holes up to 6mm before it's all over. It's hard to buy riv-nuts in small quantities. I can get a 10 pack of them from McMaster-Carr but with shipping, a 10 pack is more than a 100 kit from amazon. And something in me hates buying a bulk of things which may rarely or never be used again. The nut plate idea is a very good one and I'm going to strongly consider that. Thanks for the input! |
ChrisFoley |
Oct 31 2024, 06:20 AM
I am Tangerine Racing Group: Members Posts: 7,962 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
A friend of mine said he installed one with self tapping screws so he wouldn't have to drill holes first.
A couple of people have told me they had to remove it after installing with rivets, and then had difficulty acquiring 3 more of the 3/16 x 7/8 pop rivets. One customer mentioned that drilling for the screws had a downside - the small drill bit can go offcenter easily enough that the screws become difficult to install. A simple solution is to wrap the drill bit with tape, but that may come under the heading of an "advanced technique" which bears mention in my installation instructions. I would consider offering (or including) an alternate/upgraded fastening method if there was some consensus. |
jim_hoyland |
Oct 31 2024, 06:42 AM
What does a drill bit wrapped in tape look like ? And, how does the tape help ?
I have yet to install mine…… |
GregAmy |
Oct 31 2024, 07:36 AM
Advanced Member Group: Members Posts: 2,389 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
I am a massive fan of rivnuts, use them in any application I can, especially if the piece needs occasional removal.
That said, I've been running two of these bearings in my two cars, secured with the supplied rivets, without issue. If I had thought of rivnuts I'd have probably gone that way. But that piece shoudn't need to be removed, certainly not "occasionally". Having already secured it with the rivets then if I ever have to remove or replace it I can easily replace it with rivnuts using the same drilled holes location. Chris, I don't think you can change your design to use rivnuts given the installation tools is specialized. Pretty much any garage will have a pop rivet tool, or can get a cheap one from Home Depot. Not so much rivnuts. |
VaccaRabite |
Oct 31 2024, 11:46 AM
En Garde! Group: Admin Posts: 13,584 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I installed the spherical bushing from Chris in 2016 I think - so about 8 years and many thousands of shifts later...
The pop-rivets are starting to get loose. When freshly installed they were tight - zero play. Now when I'm under the car I can wiggle the housing that holds the ceramic bushing very minutely. It has not made any difference at all in shifting, but the pop-rivets are allowing some movement after a bunch of years in operation. I have thought about putting rivnuts in there, but won't until there is a damn good reason to unhook the shifter. BTW - this loosening could very well be rust forming on the firewall, or from just wear and tear on the pop-rivets. I drive the car a lot, and that includes through downpours that always seem to happen when I have the car over 100 miles from home. Zach |
Flyinlow |
Oct 31 2024, 04:50 PM
Flyinlow Group: Members Posts: 56 Joined: 17-October 20 From: British Columbia, Canada Member No.: 24,774 Region Association: Canada |
I also used the rivets but used j b weld on back just to keep it there
gereed75 |
Oct 31 2024, 04:58 PM
I fabbed a little nut plate to put on the interior side. Was able to install it one man that way. Rib nuts should work also. ? How did you get the plate behind the firewall ? Hmmm. Many moons ago. Don’t remember exactly. Believe it was triangular and made from thin gauge aluminum. Used aviation rivet retained nutplates. jiggered it into the hole, and I used some longish screws to skewer it Remembering back makes me like the idea of rivnuts even more Aha…it just came to me - it was circular. Put a cut through it and “spiraled” it in through the hole. Necessity being the mother of invention and all |
FlacaProductions |
Oct 31 2024, 06:05 PM
Senior Member Group: Members Posts: 1,776 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
Lo-Fi Version | Time is now: 1st November 2024 - 12:20 AM |
