96mm cylinders |
96mm cylinders |
JamesJ |
Oct 30 2024, 06:37 PM
Member Group: Members Posts: 229 Joined: 30-April 20 From: Sunnyvale, CA Member No.: 24,202 Region Association: Northern California |
I am needing to purchase 96mm cylinders for my 2056 build.
My case is a 1.8, so can/should I bore out my stock 93mm cylinders or should I purchase stock cast iron 2.0 cylinders(94mm) and have them bored out, or should I purchase aftermarket cast iron cylinders, or use birals? If I purchase stock 2.0 cylinders, should they be from the same engine case? I'm not sure who all makes cylinders, but European Motorworks says their cast iron cylinders are thicker than AA Performance cylinders. Is a thicker cylinder wall better? Any shared experience with these options is welcomed. I'm also needing a recommendation on the piston rings...Total Seal, Hastings, another brand? I will be using JE forged pistons. Thanks everyone. |
Long_ago |
Oct 30 2024, 06:57 PM
Newbie Group: Members Posts: 32 Joined: 12-May 21 From: Tracy, Ca Member No.: 25,541 Region Association: Central California |
JE Pistons = Jahns' Engineering. They make custom pistons,
As well as stock. Ask the Horse's mouth. Give them a call. Thicker cylinders are typically for higher pressures, RPM, etc. For street - I wouldn't get too exotic. Going racing? If you're not assembling the engine yourself, have a chat with the builder. Be informed so that you can decide if you agree with the builder's plan. The builder has to warranty the engine - so needs to be in a Comfort range of his/her experience. |
VaccaRabite |
Oct 30 2024, 07:33 PM
En Garde! Group: Admin Posts: 13,584 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Depending on cost, I'd bore out the stock ones. But there are lots of options on the market right now for 96mm P&C sets.
Back in the old days when I built my 2056 (15 years ago) boring out stockers and using Keith Black flattop pistons was the way to go. These days you have tons of other options. Zach |
Geezer914 |
Oct 31 2024, 12:32 AM
Geezer914 Group: Members Posts: 1,749 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
I used AA 96 mm Biral cylinders. Engine runs cool.
930cabman |
Oct 31 2024, 04:55 AM
Advanced Member Group: Members Posts: 3,640 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
Depending on cost, I'd bore out the stock ones. But there are lots of options on the market right now for 96mm P&C sets. Back in the old days when I built my 2056 (15 years ago) boring out stockers and using Keith Black flattop pistons was the way to go. These days you have tons of other options. Zach I have several sets of cast iron cylinders collecting dust in the shop, given the options, is this still a viable one for street use? |
VaccaRabite |
Oct 31 2024, 02:17 PM
I have several sets of cast iron cylinders collecting dust in the shop, given the options, is this still a viable one for street use? Yes! The question becomes "can I bore it out, have it done properly, for less then the cost of new cylinders." A good candidate for boring out will be a 2.0 cylinder that does not have cooling fins broken off. With AA P&C sets being so cheap, it may be a close thing to get your cylinders bored out and a set of KB flattop pistons and (IIRC) Hastings rings for less. My 2056 was still going very strong when I pulled it out in favor of the 2258. It was driven hard. Zach |
930cabman |
Oct 31 2024, 02:26 PM
I have several sets of cast iron cylinders collecting dust in the shop, given the options, is this still a viable one for street use? Yes! The question becomes "can I bore it out, have it done properly, for less then the cost of new cylinders." A good candidate for boring out will be a 2.0 cylinder that does not have cooling fins broken off. With AA P&C sets being so cheap, it may be a close thing to get your cylinders bored out and a set of KB flattop pistons and (IIRC) Hastings rings for less. My 2056 was still going very strong when I pulled it out in favor of the 2258. It was driven hard. Zach Thx and yes, the cost of 96 P&C's are great. I used AA last time, worked well, seated good. |
Lo-Fi Version | Time is now: 1st November 2024 - 12:39 AM |
