| Peaty |
Dec 4 2024, 10:25 PM
Newbie ![]() Group: Members Posts: 5 Joined: 18-March 22 From: CA Member No.: 26,406 Region Association: Southern California |
Does anyone have a trick to install the grommet that allows the three "Bowden cable" heater controls to pass through the interior bulk head to the heater control box located in the gas tank area?
| bdstone914 |
Dec 4 2024, 11:14 PM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,401 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Does anyone have a trick to install the grommet that allows the three "Bowden cable" heater controls to pass through the interior bulk head to the heater control box located in the gas tank area? Have not tried it on that particular gromett but lube the groove and edges of the gromett, warm it with a heat gun, wrap several rounds of waxed dental gloss in the gromett grove leaving the loose end on the side that the lip is being pulled thru. insert as much of the lip thru the hole. Tie a loop in the end of the dental floss and pull the lip of the gromett thru. pther technoque is use a smal diameter right angle pic the pull the lip thru the hole. |
| 914Sixer |
Dec 5 2024, 07:10 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,587 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
Put it in some boiling water to make it pliable.
| ClayPerrine |
Dec 5 2024, 07:37 AM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,568 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
Buy a nice, new, soft one from 914Rubber? They go in easy.
| Peaty |
Dec 5 2024, 11:15 AM
Does anyone have a trick to install the grommet that allows the three "Bowden cable" heater controls to pass through the interior bulk head to the heater control box located in the gas tank area? Have not tried it on that particular gromett but lube the groove and edges of the gromett, warm it with a heat gun, wrap several rounds of waxed dental gloss in the gromett grove leaving the loose end on the side that the lip is being pulled thru. insert as much of the lip thru the hole. Tie a loop in the end of the dental floss and pull the lip of the gromett thru. pther technoque is use a smal diameter right angle pic the pull the lip thru the hole. Thanks for the input! I'll give it a try and report back. |
| Peaty |
Dec 5 2024, 11:18 AM
| Peaty |
Dec 5 2024, 11:21 AM
| Peaty |
Jan 10 2025, 12:22 PM
SUCCESS!! I am able to put this part of my project to closure. What worked: placing the grommet in boiling water for 10 minutes to soften, silicon lubricant and sheer brute force and determination. With the hood in place, it makes it awkward to gain a good purchase to work the grommet into position but was doable. What didn't work: the suggestion of the dental floss failed as it broke on first pull. Thanks to all who offered assistance and to the 914 World Forum
| Aerostatwv |
Jan 10 2025, 03:20 PM
Member ![]() ![]() Group: Members Posts: 153 Joined: 13-July 11 From: WV Member No.: 13,315 Region Association: MidAtlantic Region
Di-electric grease is my go to when installing stubborn rubber seals.
| windforfun |
Jan 10 2025, 08:30 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,115 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None
I prefer Astroglide.
(IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) |
| busterphysic |
Jan 16 2025, 01:12 PM
Newbie ![]() Group: Members Posts: 38 Joined: 2-November 24 From: Santa Rosa, CA Member No.: 28,444 Region Association: Northern California |
I prefer Astroglide. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) That's what he/she/they said! (IMG:style_emoticons/default/piratenanner.gif) |
Lo-Fi Version | Time is now: 10th October 2026 - 03:47 AM |
