| Mikey914 |
Dec 9 2024, 09:15 PM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,786 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
I have a few sets of these ready, and can do up a few more if there is interest.
This is a great way to spruce up the bottom side when you do a valve adjust. Comes with, 2 freshly powder coated valve covers, 914Rubber thicker cork seals, 8 old school heavy wall push rod tubes with the dimple to help seat them , and 914arubber Viton seals. 8 tubes that are polished. I would like to sell on an exchange basis, but want to assure I get cores back. $100 for the parts exchange, $50 core charge paid upon return. $100 + $11.20. USPS priority mail flat rate covers anywhere in the US. 2 sets ready to go right now. Valve covers only (includes cork gaskets) powder coated $35 - $20 core $55 Shipping priority mail add $11.20. Attached thumbnail(s) |
| Mikey914 |
Dec 9 2024, 10:42 PM
Not a great shot, but put these on my 72 before I sold it.
| bdstone914 |
Dec 10 2024, 06:02 AM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,431 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I think that type of pushrod tube was used up to 73 in 1.7L engines.
They went to the later smaller diameter push rods. Possibly due to the larger exhaust tubes on 2.0 and 1.8 engines. I have sold many sets of these thinking there was no functially difference. Has anyone used the larger diameter tubes on a 2.0 or 1.8 and if so were the push rod tubes touching the exhaust tubes? |
| Mikey914 |
Dec 11 2024, 10:52 PM
I have used on 2.0 heads as well as the 1.7. Assuming 1.8 would be the same???
| bdstone914 |
Dec 12 2024, 05:55 AM
I have used on 2.0 heads as well as the 1.7. Assuming 1.8 would be the same??? The tubes will fit all heads except the cery earlt 1.7 heads which have a smaller opening for the tube and use a different size o ring. The heat exchangers for 1.7 are smaller diameter than 1 8 and 2.0. The possible issue is clearance from the push rod tube to the exhaust tube. 2.0 and 1 7-1.8 SSI exchangers have the same size id tubes. nit sure if their OD is the same as stock exchangers as the tube wall is thinner. |
| Mikey914 |
Dec 12 2024, 12:11 PM
Tube wall on these is definitely thicker. It's one of the features I like about these. No problems on my 1.7 or 2.0. You don't have to be as careful with them, worrying about crushing them, when you grab them to force into the heads and block.
| burton73 |
Dec 12 2024, 02:20 PM
Senior member, and old dude ![]() ![]() ![]() ![]() Group: Members Posts: 4,116 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California
Just curious on the push rod tubes, was there a coating or plating (like silver Zinc) on these from the factory to stop rust forming? If they are polished, they would plate well
Best Bob B |
| bdstone914 |
Dec 12 2024, 04:05 PM
Just curious on the push rod tubes, was there a coating or plating (like silver Zinc) on these from the factory to stop rust forming? If they are polished, they would plate well Best Bob B Factory finish was yellow cad or zinc. They usually leak enough oil to prevent rust. |
| Mikey914 |
Dec 16 2024, 12:29 AM
These were polished only. So the silver zinc has a coat of wax on them.
| Mikey914 |
Feb 4 2025, 03:18 AM
Still have a set left
| gtbarnes |
Feb 5 2025, 03:09 AM
Member ![]() ![]() Group: Members Posts: 50 Joined: 9-July 13 From: nash,tn Member No.: 16,111 Region Association: South East States |
I have used on 2.0 heads as well as the 1.7. Assuming 1.8 would be the same??? The tubes will fit all heads except the cery earlt 1.7 heads which have a smaller opening for the tube and use a different size o ring. The heat exchangers for 1.7 are smaller diameter than 1 8 and 2.0. The possible issue is clearance from the push rod tube to the exhaust tube. 2.0 and 1 7-1.8 SSI exchangers have the same size id tubes. nit sure if their OD is the same as stock exchangers as the tube wall is thinner. I have seen oem tubes hammered for clearance, apparently to get a socket/extension on the exh port studs(which is real tight space to start with on certain cyls). Not sure if there was a part mismatch involved or just some idiot working on it... |
| 914outlaw |
Feb 6 2025, 02:46 AM
Dave ![]() ![]() Group: Members Posts: 204 Joined: 2-June 10 From: Central, NJ Member No.: 11,800 Region Association: North East States
| Mikey914 |
Feb 7 2025, 01:10 AM
Responded to via PM
| gtbarnes |
Feb 13 2025, 06:35 AM
| Mikey914 |
Feb 17 2025, 12:00 PM
Responded to via PM So its $161.20 and if I send in my reworkable cores I get $50 back, is that right? TY Mikey Yes that is correct net is 111.20 shipped domestically USPS. These have been hanging around awhile, I'd drop it to $100 (after cores recieved). Mark |
| DRPHIL914 |
Feb 24 2026, 08:26 AM
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,971 Joined: 9-December 09 From: Kennesaw, GA Member No.: 11,106 Region Association: South East States
Responded to via PM So its $161.20 and if I send in my reworkable cores I get $50 back, is that right? TY Mikey Yes that is correct net is 111.20 shipped domestically USPS. These have been hanging around awhile, I'd drop it to $100 (after cores recieved). Mark @Mikey914 Mark, do you still have one of these sets available? Phil |
| Mikey914 |
Apr 11 2026, 01:30 PM
Responded to via PM So its $161.20 and if I send in my reworkable cores I get $50 back, is that right? TY Mikey Yes that is correct net is 111.20 shipped domestically USPS. These have been hanging around awhile, I'd drop it to $100 (after cores recieved). Mark @Mikey914 Mark, do you still have one of these sets available? Phil Sorry, Been off for awhile. I can polish up some tubes this next week, the rest is in stock. Let me know if you still need some. -Mark |
| DRPHIL914 |
Apr 14 2026, 09:51 AM
Responded to via PM So its $161.20 and if I send in my reworkable cores I get $50 back, is that right? TY Mikey Yes that is correct net is 111.20 shipped domestically USPS. These have been hanging around awhile, I'd drop it to $100 (after cores recieved). Mark @Mikey914 Mark, do you still have one of these sets available? Phil Sorry, Been off for awhile. I can polish up some tubes this next week, the rest is in stock. Let me know if you still need some. -Mark @Mikey914 Mark, I found my stash ans was able to get it taken care of, but thanks. Phil |
| Mikey914 |
Apr 14 2026, 10:03 PM
Thanks, started polishing these today and forgot how long they took. Glad you don't need them.
(IMG:style_emoticons/default/beer3.gif) |
Lo-Fi Version | Time is now: 26th November 2026 - 02:35 PM |
