> 2.0 build to 2056 or 2270?, Which cam would be best ?? Going carburetorated, with 96mm pistons
zman914
post Dec 20 2024, 06:02 PM
Looking to do a 2056 or 2270 build from a stock 2.0. Changing over to carburetorated, with 96mm pistons.. Looking for good cam advise. I'm looking for more hp, but very reliable.
iankarr
post Dec 20 2024, 07:32 PM
The wrencher formerly known as Cuddy_K
Welcome, Zman!
Going to carbs opens up a ton of options for you. It really comes down to cost and skill. If you will be rebuilding the engine yourself and you haven't done it before, I'd probably go with a proven 2056 combination. Lots of those engines on the road with good reliability. Others can chime in with specifics. If you go up to 2270, the precision needs to be higher, so it's not something I'd attempt for my first build. You'll also need to think about supplemental oil cooling.
Either way, you'll want to make sure the case checks out as a buildable core, with registers that are dead flat and parallel to the heads. I'd also swap the galley plugs for threaded ones. Good luck!
r_towle
post Dec 20 2024, 07:48 PM
Custom Member
Elgin camshafts
cgnj
post Dec 20 2024, 09:03 PM
I think you need to decide displacement before you start talking about cams. Building a big displacement type 4 today, i would run FI. That's my winter project for my 2270 motor.
post Dec 20 2024, 10:10 PM
QUOTE(zman914 @ Dec 21 2024, 07:02 AM) *
The biggest difficulty for building a 2270 for a while was finding a 78.4/78mm type iv stroker crankshaft. But, currently it looks like they're available again. With aftermarket rods, you should have very little if any clearance problems with the 2270. So, the main difference between building the 2056 versus the 2270 is the size of the spacers between the case and the cylinders (and the crankshaft stroke of 71 or 78).
Pick a Webcam (with matched lifters) appropriate for the application you will be putting the motor. Or we like tool steel lifters and crower springs. With the right cam choice it'll run just fine on carbs.
technicalninja
post Dec 20 2024, 10:26 PM
QUOTE(cgnj @ Dec 20 2024, 09:03 PM) *
(IMG:style_emoticons/default/agree.gif) Modern FI is "The Way" in my book too! (IMG:style_emoticons/default/beerchug.gif)
You've got a whole bunch of decisions to make before you start choosing cams.
Tell us about your car and your abilities.
Describe past projects, what you are comfortable doing.
Tell us what you expect the budget to be like.
And, most of all, your goals for the car.
A nice street cruiser VS a solo car VS a dedicated track monster all require different strategies...
post Dec 21 2024, 07:04 AM
We have our cam supplier (mostly Daugherty racing cams) help us with cam selection. John generally has a much better overview of the cam selection than the average builder or the home gamer.
zman914
post Dec 21 2024, 11:45 AM
Thanks for all the replies!! I'm thinking I will keep my first porsche engine rebuild simple and go with a 2056.. So best cam options!! Still would like to get the most reliable hp out of the motor.
zman914
post Dec 21 2024, 11:56 AM
Hows the web cam #86? Anyone running that cam?
cgnj
post Dec 21 2024, 12:31 PM
@zman914 Do you have the carb setup in hand? If not, then read this article by @GregAmy . He should put it behind a paywall.
https://tgadrivel.blogspot.com/2020/03/on-m...914-part-1.html
post Dec 21 2024, 01:09 PM
QUOTE(r_towle @ Dec 20 2024, 08:48 PM) *
Elgin camshafts
Give Dema a call, he will get you fixed up
technicalninja
post Dec 21 2024, 05:21 PM
QUOTE(cgnj @ Dec 21 2024, 12:31 PM) *
I just looked at "Greg's horrible waste of internet bandwidth".
I agree! That should be REQUIRED reading for anyone thinking about what options are available.
@GregAmy That might be the best guide for microsquirt I've seen!
Extremely well done AND he makes notations when time and experience has altered his original thoughts.
He built MODERN that doesn't look that way at all!
A very good system that was no more expensive than rebuilding an original D-jet.
OP, if you don't look through the link you're missing out!
And what is MOST impressive regarding the microsquirt conversion Greg walks you through is the fact that it can support ANY engine.
Stock will run better with it and WILD high compression/monster cam/stroker is only keystrokes different. At some point the intake manifold will be restrictive but the MS supports ITBs just fine.
At the point you have his "system" any engine combination will work...
JamesM
post Dec 21 2024, 06:22 PM
QUOTE(zman914 @ Dec 20 2024, 05:02 PM) *
All cams except for stock are good, but which one you want depends on your goals and the specifics of your setup.
Are you looking for bottom or top end? How high are you looking to rev it? Do you want something tame or more exciting? What sort of heads/porting/valve sizes are you using? What does your exhaust setup look like? What carbs are you running?
- Lo-Fi Version Time is now: 22nd December 2024 - 11:40 AM
