LN Engineering 2563 Kit |
JimVG |
Dec 26 2024, 04:36 PM
Newbie Group: Members Posts: 33 Joined: 10-October 24 From: Gig Harbor, WA Member No.: 28,402 Region Association: Pacific Northwest |
Has anyone here built a 914 Type 4 using the LN Engineering 2563-190 kit?
Root_Werks |
Dec 26 2024, 07:06 PM
Village Idiot Group: Members Posts: 8,565 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
Hoping someone will chime in. Years back, really wanted to build a "2.5" 4cyl.
zig-n-zag |
Dec 27 2024, 02:48 AM
Member Group: Members Posts: 200 Joined: 18-May 06 From: Hawaii Member No.: 6,024 |
I bought a 2563-190 engine kit from Jake Raby back in 2006.
I’ve not been able to devote the time to put it together as other things in life have taken priority. What do you need to know? I hope I can answer any questions you have. |
JimVG |
Dec 27 2024, 07:33 AM
I bought a 2563-190 engine kit from Jake Raby back in 2006. I’ve not been able to devote the time to put it together as other things in life have taken priority. What do you need to know? I hope I can answer any questions you have. Thanks for the reply! I am strongly considering this kit. I would like to know how this engine performs, choices regarding induction (carbs vs EFI), exhaust, oil coolers, DTM, etc. |
DC_neun_vierzehn |
Dec 27 2024, 08:51 AM
Member Group: Members Posts: 493 Joined: 16-November 20 From: Delaware Shore Member No.: 24,893 Region Association: MidAtlantic Region |
I bought a 2563-190 engine kit from Jake Raby back in 2006. I’ve not been able to devote the time to put it together as other things in life have taken priority. What do you need to know? I hope I can answer any questions you have. Wow ... almost a 20 year time capsule kit. I hope life allows you to get to it sometime soon. |
JOEPROPER |
Dec 27 2024, 08:57 AM
The answer is "no" unless you ask... Group: Members Posts: 1,193 Joined: 21-November 15 From: White Plains New York Member No.: 19,387 Region Association: North East States |
If you go with carbs, I have big Dells that are new. I'm not using them so if you need, let me know. Good luck with your project!
r_towle |
Dec 27 2024, 09:03 AM
Custom Member Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
I have a 2.6
Carbs were required at the time I built it over 10 years ago, but I’m going to move over to ITB with some aftermarket EFI system. The more recent EFI kits seem to better tested nowadays. For a kit, jake makes sure everything fits..harder todo now because many parts are lower quality. For power, my 2.6 got just over 200HP on a dyno. It is not streetable (think 5-6500 rpm’s) so I’m going to pull it back apart now that I no longer race, and put a milder camshaft in place. It will make somewhere between 150-175 hp Is it worth it? Well for me it was a challenge to get 200 hp from a type 4 motor. |
r_towle |
Dec 27 2024, 10:10 AM
No matter what you choose, measure everything to ensure it’s round, and the correct size, particularly the pistons and cylinders
zig-n-zag |
Dec 27 2024, 02:45 PM
I had Jake do the engine prep which was wrist pin fit, ring gap for the nickies, and side play on the rods, and his full race-balance spec.
I don’t know if the rod bearings need trimming to clear the rod journal fillets, and that’s something to check. I went with the DTM fan shroud kit and added a tig welded and balanced type 1 super beetle fan. The fan that came with the engine kit didn’t have welded fins. I bought new Spanish 44mmIDF carbs from Jake, and upgraded the venturis to 38mm from CB. I also have a set of Spanish 48mm IDF’s ready to go. Those have the stock 40mm venturis fitted, but thinking of adding the grooved 40mm venturis from Berg and taller 6 inch air horns from CB for more air velocity and capturing more fuel fog. The coated header is 1-3/4” 4-2-1 built by CFR, and the muffler is the twin center mount pipe version. Jake provided the ignition system, Mallory unilite dizzy and the 685 amplifier box. Ignition wires are from CFR. I planned to stay with a wet sump oiling, but broke down last month and bought a 914/6 oil tank from Ben to keep my options open on going dry sump. |
technicalninja |
Dec 27 2024, 02:54 PM
Advanced Member Group: Members Posts: 2,377 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
I had Jake do the engine prep which was wrist pin fit, ring gap for the nickies, and side play on the rods, and his full race-balance spec. I don’t know if the rod bearings need trimming to clear the rod journal fillets, and that’s something to check. I went with the DTM fan shroud kit and added a tig welded and balanced type 1 super beetle fan. The fan that came with the engine kit didn’t have welded fins. I bought new Spanish 44mmIDF carbs from Jake, and upgraded the venturis to 38mm from CB. I also have a set of Spanish 48mm IDF’s ready to go. Those have the stock 40mm venturis fitted, but thinking of adding the grooved 40mm venturis from Berg and taller 6 inch air horns from CB for more air velocity and capturing more fuel fog. The coated header is 1-3/4” 4-2-1 built by CFR, and the muffler is the twin center mount pipe version. Jake provided the ignition system, Mallory unilite dizzy and the 685 amplifier box. Ignition wires are from CFR. I planned to stay with a wet sump oiling, but broke down last month and bought a 914/6 oil tank from Ben to keep my options open on going dry sump. OK that's SERIOUS! (IMG:style_emoticons/default/ninja.gif) Please make a build thread when you do it! (IMG:style_emoticons/default/popcorn[1].gif) |
930cabman |
Dec 27 2024, 03:16 PM
Advanced Member Group: Members Posts: 3,874 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
How are these large modifications long term?
Better value with a /6 conversion? |
zig-n-zag |
Dec 27 2024, 04:35 PM
I wonder if you folks remember in the Paddock the racer who had broken his crankshaft in half, rebuilt it with all new parts and suffered the same thing again?
Same thing happened to me way back in 1989, though my engines were type 1 draw thru turbos. Yep, 2 engines in a row, broken cranks and major rod journal damage. The cause was because they were not treated with tufftriding (at the time) or the highest level of heat treatment which is nitriding. The industry standard of induction-hardening cannot sustain anything over 6000rpm. Nitriding a crank is done before final machining to size. If the crank has already been machined to size, cryogenic treatment is an acceptable way to strengthen and to prevent cracking the crank and destroying the engine. The rod journals suffer oil starvation because the non-hardened crank bends and flexes over 6000rpm. This puts stress on the conrods running out of alignment and causes the pistons to scuff the barrels. |
zig-n-zag |
Dec 27 2024, 04:57 PM
Good friend of mine built a 2.7 6 for his ‘77 911, E cams, S pistons, and
40IDAs with 34 Venturis and correct distributor. Got to drive it like I stole it, but I couldn’t get over how thirsty that engine was. His ‘83 with the 3.0 CIS has strong torque down low, but not very exciting. I’m sure a 3.2 would satisfy me. But let me try a 200hp type 4 first. |
JimVG |
Dec 27 2024, 04:59 PM
JimVG |
Dec 27 2024, 05:05 PM
I had Jake do the engine prep which was wrist pin fit, ring gap for the nickies, and side play on the rods, and his full race-balance spec. I don’t know if the rod bearings need trimming to clear the rod journal fillets, and that’s something to check. I went with the DTM fan shroud kit and added a tig welded and balanced type 1 super beetle fan. The fan that came with the engine kit didn’t have welded fins. I bought new Spanish 44mmIDF carbs from Jake, and upgraded the venturis to 38mm from CB. I also have a set of Spanish 48mm IDF’s ready to go. Those have the stock 40mm venturis fitted, but thinking of adding the grooved 40mm venturis from Berg and taller 6 inch air horns from CB for more air velocity and capturing more fuel fog. The coated header is 1-3/4” 4-2-1 built by CFR, and the muffler is the twin center mount pipe version. Jake provided the ignition system, Mallory unilite dizzy and the 685 amplifier box. Ignition wires are from CFR. I planned to stay with a wet sump oiling, but broke down last month and bought a 914/6 oil tank from Ben to keep my options open on going dry sump. Awesome. Thanks for the info. As you are most likely aware, Jake sold his “Air Cooled Technology” business to LN Engineering who now sells Jake’s Type 4 kits. I am going to have them do all the case prep work and coating. |
Chris914n6 |
Dec 27 2024, 05:24 PM
Jackstands are my life. Group: Members Posts: 3,437 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Subaru makes a 2.5L that is significantly cheaper, includes FI, and is more reliable. Also has an option to add a modern transmission with a smooth cable shift.
Plus when you get bored with it you can upgrade to a 2.5L with turbo. Or you can choose a sweet 3L 6 version. Has anyone here built a 914 Type 4 using the LN Engineering 2563-190 kit? |
930cabman |
Dec 27 2024, 05:28 PM
Subaru makes a 2.5L that is significantly cheaper, includes FI, and is more reliable. Also has an option to add a modern transmission with a smooth cable shift. Plus when you get bored with it you can upgrade to a 2.5L with turbo. Or you can choose a sweet 3L 6 version. Has anyone here built a 914 Type 4 using the LN Engineering 2563-190 kit? but it's a Subaru |
zig-n-zag |
Dec 27 2024, 05:39 PM
The camshaft in the engine kit is the 163/86b. What makes this cam
different is the 104* lobe centers. The dual valve springs will need to be cryogenic treated so they can maintain proper tension to the valves and hold the lifters to the cam. If not, the valve hits the seat a little off, Damaging its ability to seal, there by losing power. Left to continue, it will Wear on the valve guide and valve stem, and eventually having the valve Heads touching each other while opening and closing. A clue to having the Valve springs lose tension is an increase in valve lash. This is critical if you Want to run real big valves like 48 intake and 38 exhaust. |
technicalninja |
Dec 27 2024, 06:23 PM
The camshaft in the engine kit is the 163/86b. What makes this cam different is the 104* lobe centers. The dual valve springs will need to be cryogenic treated so they can maintain proper tension to the valves and hold the lifters to the cam. If not, the valve hits the seat a little off, Damaging its ability to seal, there by losing power. Left to continue, it will Wear on the valve guide and valve stem, and eventually having the valve Heads touching each other while opening and closing. A clue to having the Valve springs lose tension is an increase in valve lash. This is critical if you Want to run real big valves like 48 intake and 38 exhaust. Not sure I understand some of this... "Valve heads hitting" and "gaining lash from weak springs". |
zig-n-zag |
Dec 27 2024, 06:30 PM
In the long term, how long will a Porsche 6 last compared with the Type 4?
Originally, I wanted to do a 2.7MFI 6. Collected the parts, 7R, 915, then Priced the MFI set up and choked. Decided then and there what might be More fun for me. Using the highest quality parts will yield the longest life. Not going overboard on too much cam, too much carburatiopn, and too Compression will make for a long lasting engine. |
Lo-Fi Version | Time is now: 5th February 2025 - 03:36 AM |
