> 914 tachometer indicator lights?, Why are there two different 914 tach displays (turn indicator lights)?
Jezibel
post Jan 10 2025, 05:54 PM
Das Echte POORSCHE Fahrer
OK, would some wise soul (George/Dr. 914?) please explain to me why there are apparently two different VDO tachs found in 914s...one of which has separate green arrows for left and right turn indicator actuation and the other with a single left side light for both turn indicators and a right-side light indicator that high beam is on?
I refer, of course, to the two small indicator bulbs that sit at the top of the tach face on top-left and top-right? Most cars have separate L/R turn indicator lights, but apparently the Porsche 914 was equipped with both types of tachs?
I vaguely recall that the early 914s had the two green arrow indicators type, and later models used the left turn indicator and right high-beam on-indicator type. Thanks in advance.
(IMG:style_emoticons/default/confused24.gif)
Spoke
post Jan 10 2025, 08:06 PM
Jerry
The '70-'73 models had the separate turnsignal indicators in the tach. The '74-'76 had the single L/R indicator.
I'm not sure why they changed over.
Retroracer
post Jan 11 2025, 12:23 PM
Model year change, as @Spoke suggested. Probably motivated by cost savings; another trend was later tachs switched to a polycarbonate lens, from the earlier glass. Also the indicator (pointer) assembly was switched to mostly plastic iin later models - FYI
- Tony
Jezibel
post Jan 11 2025, 02:29 PM
Thanks for that clarification, Tony & Jerry. That seems to mirror something along those lines I read elsewhere. Since having a separate L & R indicator light is, in my opinion, quite helpful (nothing irritates me more than carefree people riding along on the freeway with their turn indicators winking merrily away!), perhaps I could acquire one of the earlier year tach instruments and install it in place of my OEM '74 unit. Hopefully no wiring changes would be required. As far as the indicator needle goes, I much prefer the all black version (later type) to the central silver hub type.
post Jan 11 2025, 04:41 PM
914 Wiring Harnesses
The wiring harness is different. You’ll need to do some custom wiring to make this work.
dtmehall
post Jan 11 2025, 08:02 PM
and maybe a different flasher relay
Spoke
post Jan 12 2025, 09:47 AM
Jerry
QUOTE(Jezibel @ Jan 11 2025, 03:29 PM) *
@Jezibel
I did that exact same swap on my '74 914. I swapped the tach case but kept the '74 tach mechanism.
You need to have an extra bulb socket, make a small pigtail and run the L and R indicator wires to the hazard switch where all the turnsignal wires end up. Ground the indicators on the tach.
Here's a link with pictures to show how I did the swap.
Swapping '74 Tach for '72 Tach
Jezibel
post Jan 12 2025, 01:21 PM
[/quote] I did that exact same swap on my '74 914. I swapped the tach case but kept the '74 tach mechanism.
Here's a link with pictures to show how I did the swap. [/quote]
Wow! Thanks for that detailed and illustrated Tach conversion protocol, Jerry! That's pretty impressive to someone like me who has trouble differentiating (+) from (-), electrically speaking. I may try to follow suit but your instructions are pretty clear and the illustrating photographs are perfect, also. I continue to be amazed by the automotive resto-skills of people such as yourself and others on the forum! Clearly, a major part of my knowledge base in automotive repairs and maintenance is deficit. (IMG:style_emoticons/default/welder.gif) (IMG:style_emoticons/default/pray.gif) Thank you!
Jezibel
post Jan 12 2025, 01:23 PM
QUOTE(JeffBowlsby @ Jan 11 2025, 02:41 PM) *
Thanks for that Jeff (and also to dtmehall) for your insights. Most appreciated!
Dave_Darling
post Jan 15 2025, 02:53 PM
914 Idiot
Interestingly, the very early 74 cars had leftover 73 tachs with silver-dot centers and two turn signal indicators, but ran the later wiring to them. A jumper wire connected the two arrows together so they would both blink when either signal was used.
I'm pretty sure this was done for cost saving reasons. I believe the 911 also changed the same way at about the same time.
--DD
Root_Werks
post Jan 15 2025, 03:12 PM
Village Idiot
Had to do this when I switched to a 911 tach. I think I just ran a wire from the fuse block for each side. Easy-peasy.
flipb
post Jan 15 2025, 03:20 PM
QUOTE(Dave_Darling @ Jan 15 2025, 03:53 PM) *
--DD
I've got that setup in my Sept '73 build.
- Lo-Fi Version Time is now: 5th February 2025 - 06:43 AM
