> Installing the shifter springs
jrrobertson
post Jan 11 2025, 09:03 PM
I can't get the shifter springs installed. I thought there was a thread on this but I could not find it. Could anyone share the procedure with me or tell me where I can locate the instructions?
Garland
post Jan 11 2025, 09:14 PM
Restoration Fanatic
Here’s the link:
“2012 World post link”
@jrrobertson
jrrobertson
post Jan 11 2025, 09:19 PM
Thanks, John. See you Monday.
post Jan 11 2025, 09:38 PM
I did the punch but I grabbed the other end with vice grips and forced the spring into the other holes location. Then moved the vice grips tilting sideways to start flattening the spring into place as I am putting pressure on the punch to drive it through the spring to the other holes location. It worked really well even with limited room.
r_towle
post Jan 11 2025, 10:16 PM
Custom Member
A vice is much safer….just sayin
post Jan 12 2025, 05:59 AM
However you do it, wear eye protection
Puebloswatcop
post Jan 12 2025, 09:56 AM
QUOTE(mepstein @ Jan 12 2025, 05:59 AM) *
Eye protection and body armor... (IMG:style_emoticons/default/av-943.gif)
rhodyguy
post Jan 12 2025, 10:26 AM
Chimp Sanctuary NW. Check it out.
Slip a putty knife into the spring end without the pin started. Pin slightly in, put other end in place, the spring will be bowed upward. Push down on the spring and work the pin in. Takes about 5 minutes.
post Jan 12 2025, 10:52 AM
I use a Phillips screwdriver and vise grips. Takes 30 seconds. Once the spring is on the screwdriver shaft, slide in the pin as you remove the screwdriver. I also wear leather gloves because that spring is under a lot of tension but use the vice grips to hold the spring.
Ron914
post Jan 12 2025, 11:17 AM
I need to do this to my car , I bought two new springs from 914Rubber but I see in Shivers post he installed four springs .What is the advantage of four springs ?
technicalninja
post Jan 12 2025, 02:03 PM
Stiffens the assembly.
A little bit less "slop".
More precise maybe...
Doubles the chances of puncturing/wounding yourself during assembly!
914 enthusiasts are machoistic.
It's a required trait...
post Jan 12 2025, 04:42 PM
Before you do that, looking at your image you may consider repairing or replacing your shift plate
Ron914
post Jan 12 2025, 05:17 PM
QUOTE(914werke @ Jan 12 2025, 05:42 PM) *
Hi ,
Are you saying that if your shift plate is damaged or needs replaced adding 2 more springs will not help the situation. My car is new to me and I have to carefully shift my car into gears sort of guiding it into the right path for the gears so I don't hit the wrong gear . I also haven't driven a manual now for some years and find the 914 shifter more difficult than manual cars I have driven in the past.I have seen the cool parts you sell and will be doing business with you soon for your brass shift bushings and taco plate kit, actually when I decide to make my purchase can I call first for some advice before I order something?
post Jan 13 2025, 01:57 PM
QUOTE(technicalninja @ Jan 12 2025, 12:03 PM) *
Rick,
Is this a guess?
This part is true for sure:
I have never heard of this on the 4 springs.
Best Bob B
post Jan 13 2025, 02:21 PM
QUOTE(burton73 @ Jan 13 2025, 11:57 AM) *
Rick,
Is this a guess?
Best Bob B
@Ron914
Hahahahaha
When in a hurry shifting it was not uncommon for me to nick reverse. 1st to 2nd, or any other gear to second. The springs hold that plate in place that keeps the shifter out of 1st and reverse, gears I do not use very often. So it will be more effort to get the shifter over there to 1st and reverse, but that is exactly what I am hoping for.
Ron914
post Jan 13 2025, 02:38 PM
QUOTE(Shivers @ Jan 13 2025, 03:21 PM) *
Rick,
Is this a guess?
Best Bob B
@Ron914
Hahahahaha
Ouch ,it bothers me if I grind a gear (what damage is this doing to my transmission ?) I found that if I put the car in first before reverse it goes in easy ( I was told reverse has no synchros , I also have discovered if I slip it into neutral when I come to a light that I need to double clutch it so it will go into first but if you leave the clutch in as you roll up to a light it goes in first easy . I haven't driven a manual in a while and forgot this . This might be a sign my transmission needs some attention.
rhodyguy
post Jan 13 2025, 02:47 PM
Once out of the 1st/R plain, the plate can act as a guide providing clean engagement of 2 gear. Try it! Beware of excessive ware on the shift lever at the plate contact point. Speed shifting and banging gears is best left to drag strips.
- Lo-Fi Version Time is now: 5th February 2025 - 06:54 AM
