| jbell959 |
Jan 17 2025, 09:59 PM
Newbie ![]() Group: Members Posts: 13 Joined: 2-May 21 From: CA Member No.: 25,505 Region Association: None |
I built this for someone last year and they decided to go with early style gauges. It started life as a 74 914 tach and the face was redone to look like a 911 SC/Carrera tach.
A factory 6-cyl VDO driver board was installed so this will work with CDI or Motronic. If you need it to work with MSD or another ignition type I can swap the board for an additional charge. I'd like to get $375 shipped ... Reduced to $350 shipped ... Reduced to $325 shipped Attached thumbnail(s) |
| mb911 |
Jan 18 2025, 08:04 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,682 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest
Great price and great products
| jbell959 |
Feb 9 2025, 11:48 AM
I still have this. One to offers or trades
| jbell959 |
Feb 19 2025, 09:45 AM
Someone needs this. Make me an offer
| jbell959 |
Apr 1 2025, 01:30 PM
| jbell959 |
May 12 2025, 09:39 PM
One more bump and it will probably come apart to be used for other projects. Or I can reinstall the original driver board and calibrate it for a 4-cyl.
| 69146 |
May 13 2025, 08:21 AM
I'm new here ... Group: Members Posts: 0 Joined: 18-August 23 From: Oldsmar Member No.: 27,532 Region Association: None |
One more bump and it will probably come apart to be used for other projects. Or I can reinstall the original driver board and calibrate it for a 4-cyl. Hi John. Can these be changed to silver dots and the tach for carbs and if so what would be the additional cost Thx David |
| 69146 |
May 13 2025, 08:22 AM
One more bump and it will probably come apart to be used for other projects. Or I can reinstall the original driver board and calibrate it for a 4-cyl. Hi John. Can these be changed to silver dots and the tach for carbs and if so what would be the additional cost Thx David Keeping as a six also |
| jbell959 |
May 13 2025, 08:38 AM
[/quote]
Hi John. Can these be changed to silver dots and the tach for carbs and if so what would be the additional cost Thx David [/quote] Yes, but honestly, it doesn't make sense to change the needle on this one. To make it correct for an early car, you'd also want to change the bezel. On top of that, the later 74-on 914 tachs have a single turn signal indicator versus left and right on the early cars. It would be better to start with an early tach. Let me know if I can help. |
| jbell959 |
Jun 3 2025, 07:58 AM
$325 Shipped
| jbell959 |
Nov 15 2025, 09:44 AM
I still have this one
| scallyk9 |
Nov 15 2025, 06:30 PM
Member ![]() ![]() Group: Members Posts: 365 Joined: 16-October 16 From: Port Orchard, WA, USA Member No.: 20,499 Region Association: Pacific Northwest
Beautiful restoration. Question sent via PM.
Lo-Fi Version | Time is now: 16th November 2025 - 02:50 PM |
