| enoz05 |
Feb 7 2025, 07:19 AM
Newbie ![]() Group: Members Posts: 19 Joined: 24-May 17 From: Europe Member No.: 21,126 Region Association: Europe |
FS: Long and short Bosch red banjo horns, date code 029 (Sept '70) and 031 (Nov '70). Both horns are working very good and are in decent condition without any cracks. Price 595 euro + shipping.
Attached thumbnail(s) |
| bdstone914 |
Feb 7 2025, 08:00 AM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,342 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
| gtbarnes |
Feb 8 2025, 05:48 PM
Member ![]() ![]() Group: Members Posts: 50 Joined: 9-July 13 From: nash,tn Member No.: 16,111 Region Association: South East States |
Mounting tabs suggest they are new/nos? Was this a Euro option?
| bdstone914 |
Feb 8 2025, 08:52 PM
Mounting tabs suggest they are new/nos? Was this a Euro option? They don't look like NOS with rusted screws and a bent electrical terminal. I have several pair and the red is much brighter than any i have. Those horns also have a Bosch part number on the disc below the mounting bracket. I thought they were only used on 911's. but i guess they would mount behind the bumper. |
| enoz05 |
Feb 9 2025, 07:18 AM
| bdstone914 |
Feb 9 2025, 08:51 AM
Mounting tabs suggest they are new/nos? Was this a Euro option? These are used banjo horns and do not have a bent electrical connection Not a big issue but what am I seeing on the spade connector on the right? looks to be curled over Attached thumbnail(s) |
| enoz05 |
Feb 9 2025, 10:12 AM
Mounting tabs suggest they are new/nos? Was this a Euro option? These are used banjo horns and do not have a bent electrical connection Not a big issue but what am I seeing on the spade connector on the right? looks to be curled over The spade connectors are not bent at all. I will clean them for you and take better pictures. |
| Retroracer |
Feb 9 2025, 11:34 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 664 Joined: 7-July 13 From: Bend OR Member No.: 16,100 Region Association: Pacific Northwest
Mounting tabs suggest they are new/nos? Was this a Euro option? They don't look like NOS with rusted screws and a bent electrical terminal. I have several pair and the red is much brighter than any i have. Those horns also have a Bosch part number on the disc below the mounting bracket. I thought they were only used on 911's. but i guess they would mount behind the bumper. Were used on the factory GTs, as you suggest, mounted behind the (fiberglass) bumper. FYI, ![]() - Tony |
| enoz05 |
Feb 10 2025, 08:43 AM
Mounting tabs suggest they are new/nos? Was this a Euro option? These are used banjo horns and do not have a bent electrical connection Not a big issue but what am I seeing on the spade connector on the right? looks to be curled over I cleaned them up a bit and as you can see they are completely straight, not bent, not curled over Attached thumbnail(s) |
| bdstone914 |
Feb 10 2025, 09:33 AM
@Retroracer
@914wes ' date='Feb 9 2025, 11:34 AM' post='3191134'] [quote name='bdstone914' post='3191049' date='Feb 8 2025, 06:52 PM'] [quote name='gtbarnes' post='3191012' date='Feb 8 2025, 05:48 PM'] Mounting tabs suggest they are new/nos? Was this a Euro option? [/quote] They don't look like NOS with rusted screws and a bent electrical terminal. I have several pair and the red is much brighter than any i have. Those horns also have a Bosch part number on the disc below the mounting bracket. I thought they were only used on 911's. but i guess they would mount behind the bumper. [/quote] Were used on the factory GTs, as you suggest, mounted behind the (fiberglass) bumper. FYI, ![]() Thank you. Did they use two different frequency tones ? - Tony [/quote] |
| bdstone914 |
Feb 10 2025, 09:36 AM
Mounting tabs suggest they are new/nos? Was this a Euro option? These are used banjo horns and do not have a bent electrical connection Not a big issue but what am I seeing on the spade connector on the right? looks to be curled over I cleaned them up a bit and as you can see they are completely straight, not bent, not curled over Thank you good luck with sale. I wold list them on teh 911S early registry too as they were used on 911 too. |
| enoz05 |
Feb 11 2025, 03:59 PM
Mounting tabs suggest they are new/nos? Was this a Euro option? These are used banjo horns and do not have a bent electrical connection Not a big issue but what am I seeing on the spade connector on the right? looks to be curled over I cleaned them up a bit and as you can see they are completely straight, not bent, not curled over Thank you good luck with sale. I wold list them on teh 911S early registry too as they were used on 911 too. Thanks |
| enoz05 |
Feb 21 2025, 10:18 AM
These are still available
| enoz05 |
Feb 27 2025, 05:40 AM
These horns are sold, thanks
Lo-Fi Version | Time is now: 30th July 2026 - 05:16 PM |
