morehills |
Member ![]() ![]() Group: Members Posts: 85 Joined: 2-March 23 From: Great Barrington, MA Member No.: 27,202 Region Association: North East States ![]() ![]() |
Does anyone have any experience with this heated windshield solution from the UK?
https://www.heatedwindscreen.com/products/p...lear-windscreen I have a GT clone with no heat or ventilation. It does have heated seats, and I would love a heated windshield for foggy morning drives. Yes, I know I can add back heat and/or ventilation, but I'm running headers going back to the stock set up would be both expensive and weighty. Perhaps someone has imported one or a UK member can weigh in on the performance of this windscreen. |
930cabman |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,926 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States ![]() ![]() |
Does anyone have any experience with this heated windshield solution from the UK? https://www.heatedwindscreen.com/products/p...lear-windscreen I have a GT clone with no heat or ventilation. It does have heated seats, and I would love a heated windshield for foggy morning drives. Yes, I know I can add back heat and/or ventilation, but I'm running headers going back to the stock set up would be both expensive and weighty. Perhaps someone has imported one or a UK member can weigh in on the performance of this windscreen. My recent 1975 example has the hot air system working properly (I think) and it defrosts the windscreen quickly. Also, I am not running a thermostat |
draucci |
Newbie ![]() Group: Members Posts: 9 Joined: 5-March 04 Member No.: 1,754 Region Association: Upper MidWest ![]() ![]() |
Hello Morehills,
My '82 911SC came with a factory heated windscreen. The bottom 6 inches (approximately) of the windshield has very fine filament type wire running horizontally from side to side. The wire cannot be seen unless you look at the windshield from a particular angle. It does not affect vision at all. The heating element is activated by one of the pull switches on the dash. I have not used the feature recently, but as I recall, it worked pretty good. Similar to heated rear windows. Does anyone have any experience with this heated windshield solution from the UK? https://www.heatedwindscreen.com/products/p...lear-windscreen I have a GT clone with no heat or ventilation. It does have heated seats, and I would love a heated windshield for foggy morning drives. Yes, I know I can add back heat and/or ventilation, but I'm running headers going back to the stock set up would be both expensive and weighty. Perhaps someone has imported one or a UK member can weigh in on the performance of this windscreen. |
Literati914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,837 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region ![]() |
Hello Morehills, My '82 911SC came with a factory heated windscreen. The bottom 6 inches (approximately) of the windshield has very fine filament type wire running horizontally from side to side. The wire cannot be seen unless you look at the windshield from a particular angle. It does not affect vision at all. The heating element is activated by one of the pull switches on the dash. I have not used the feature recently, but as I recall, it worked pretty good. Similar to heated rear windows. That seems like a good, cheap option. Shipping that glass is gonna be expensive. I believe you can purchase those type heating elements with an adhesive backing. I've also wondered about the small box heating units like they sell on amazon ... but they use about 800w of power, so you'd need a huge Alternator I guess. Is there an Alternator option that would work - you tell me? : https://www.amazon.com/Riloer-Windshield-De...B0CGC72BJD?th=1 |
rfinegan |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,053 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region ![]() ![]() |
better have big alternator, if its electric, IM sure it pulls some amp(based not the instClease of the early 80 cars like Lincolns/prem fords I have worked on)
VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,672 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() ![]() |
My car has no heat and I tend to run it year round as long as the roads arent salted.
Wear warm clothes, keep your windows cracked open. Have a rag in the car just in case, but fogging generally isn't an issue. A 914 can't spare the amps to run electric heated windshields. Not unless you put in a much larger alternator. I'm sure you are already pushing the limits with the electric seat warmers. I would suggest putting the heating system back in if the cold is starting to get to you. You won't notice the added weight when you are warm. I've been intending to take my own advice for like 5 years now but have not gotten around to it... Zach |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,135 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
Yes, I know I can add back heat and/or ventilation, but I'm running headers going back to the stock set up would be both expensive and weighty. Get a Webasto gasoline heater. Only a few pounds of weight about as low in the car as it gets, pipe the output into the air system and enjoy an early morning sauna. (IMG:style_emoticons/default/cheer.gif) |
930cabman |
My car has no heat and I tend to run it year round as long as the roads arent salted. Wear warm clothes, keep your windows cracked open. Have a rag in the car just in case, but fogging generally isn't an issue. A 914 can't spare the amps to run electric heated windshields. Not unless you put in a much larger alternator. I'm sure you are already pushing the limits with the electric seat warmers. I would suggest putting the heating system back in if the cold is starting to get to you. You won't notice the added weight when you are warm. I've been intending to take my own advice for like 5 years now but have not gotten around to it... Zach must be a dyed in the wool bug owner? always carry an ice scraper in your left hand. The stock heating system works very well |
Literati914 |
According to google, an 800W unit (like the electric one I linked to above) needs about 67 amps on a 12V system. Someone used to offer a 160A alternator for the 914, right?
jcd914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,083 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California ![]() |
From their website:
On this drawing we have used 25AMP circuits as this covers nearly all of our windscreens! Some of the largest screens we do for example Civics and VW Transporters may need up to 35AMPs per side - if you are unsure call us! |
930cabman |
From their website: On this drawing we have used 25AMP circuits as this covers nearly all of our windscreens! Some of the largest screens we do for example Civics and VW Transporters may need up to 35AMPs per side - if you are unsure call us! 35 amps per side? how can this be would somebody really ramp up 70 amps to defrost their windscreen (IMG:style_emoticons/default/idea.gif) |
Lo-Fi Version | Time is now: 26th February 2025 - 10:08 AM |
