Mr.Vman |
Newbie ![]() Group: Members Posts: 15 Joined: 1-October 24 From: Sierra Vista, AZ. Member No.: 28,388 Region Association: Southwest Region ![]() |
Moving toward dual carburetors on my, 1976 914, 2.0. I know should keep the fuel injection and am being a fool to not use the fuel injection. The car will be a driver, no racing, crusing, fun. Anyway, 2.0, will build a mild engine, mild camshaft, maybe a, 78mm stroker, some head work, back dated heat exchangers with Burch exhaust/muffler. Looking at; 40's probably better drivability or 44's. Not sure on EMPI's or Webers yet. Linkage? Cross bar? has problems and bell crank has problems so a recommendation on carburetors and linkage? Anything else? Thank for the time and information
flipb |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,796 Joined: 2-September 09 From: Fairfax, VA Member No.: 10,752 Region Association: MidAtlantic Region ![]() ![]() |
I have a 2056cc with EMPI 40 carbs. If I were starting a build today, I would be fine with the EMPI carbs but I would've sent them off to be prepped. IIRC Jake Raby supposedly had a process for "fixing" brand new EMPI carbs, and there might have been someone else on the forum who offered that as a service.
Also if starting a build today I would've strongly considered Tangerine Racing's cable linkage. |
rfinegan |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,053 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region ![]() ![]() |
Sync link (type 4 store) or Tangerine cable system
40 idf clone or used weber 40 idf both will need going through/rebuild |
technicalninja |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,444 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region ![]() ![]() |
2.0l 40 IDF with 27mm chokes.
2256 (stroker) would work with 40s 32 mm chokes. Bigger motor really should move up to 44s with 32mm chokes. |
thomasotten |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,564 Joined: 16-November 03 From: San Antonio, Texas Member No.: 1,349 ![]() |
Dellorto 40 DRLA, find a good used pair, preferably professionally rebuilt.
barefoot |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,345 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States ![]() ![]() |
Dellorto 40 DRLA, find a good used pair, preferably professionally rebuilt. I'll second that recommendation (IMG:style_emoticons/default/beerchug.gif) Barefoot |
Lo-Fi Version | Time is now: 26th February 2025 - 10:20 AM |
