mitchg27 |
Newbie ![]() Group: Members Posts: 4 Joined: 8-November 23 From: california Member No.: 27,716 Region Association: Southern California ![]() |
Purchased from a seller on 914 world Jan. 2024. Planned to restore but now have decided i dont have the time to complete.
Looking to sell to someone who can complete restoration. Completed so far all 4 corners brake system Disk rotors, pads, hoses, Calibers refurbushed at PMB. Engine and trans removed , all push rod tube selas replaced, new oil cooler and seals, rear main seal replaced, New clutch, flywheel resurfaced. replaced exhuast manifold with used good manifold and used dansk muffler. All trans linkage bushings replaced. 2 New CV axle assy. 4 new tires. Ignition switch replaced, hand parking brake repaired. Still needs to be completed Interior and paint. Asking $12,500 located in Riverside Calif. ![]() ![]() ![]() ![]() |
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California ![]() |
Purchased from a seller on 914 world Jan. 2024. Planned to restore but now have decided i dont have the time to complete. Looking to sell to someone who can complete restoration. Completed so far all 4 corners brake system Disk rotors, pads, hoses, Calibers refurbushed at PMB. Engine and trans removed , all push rod tube selas replaced, new oil cooler and seals, rear main seal replaced, New clutch, flywheel resurfaced. replaced exhuast manifold with used good manifold and used dansk muffler. All trans linkage bushings replaced. 2 New CV axle assy. 4 new tires. Ignition switch replaced, hand parking brake repaired. Still needs to be completed Interior and paint. Asking $12,500 located in Riverside Calif. ![]() ![]() ![]() ![]() Email sent. I'm next door in Corona. Thanks, Aaron |
rick 918-S |
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,932 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region ![]() ![]() ![]() |
Go for it Aaron (IMG:style_emoticons/default/bye1.gif)
mitchg27 |
Bump
andrewvolsen |
Newbie ![]() Group: Members Posts: 44 Joined: 6-December 09 From: Santa Barbara Member No.: 11,099 Region Association: Central California ![]() |
Are the engine and trans currently installed in the car? Does it currently run? EFI or carbs? Tail shift or side shift trans?
mitchg27 |
burton73 |
Senior member, and old dude ![]() ![]() ![]() ![]() Group: Members Posts: 3,806 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California ![]() ![]() |
Lo-Fi Version | Time is now: 29th April 2025 - 03:17 AM |
