> Blacked Out Gauge Kits and components., Back from ice storm. Will update these older posts ty
gtbarnes
post Mar 8 2025, 07:24 PM
Last chance for Monday! Secure next weekends project now!Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Probably the most satisfying thing you can do to your 914. Very easy on the eyes from dark to lit to bright, every range in between. https://gtbarnes914.com/
What about a UV Fluorescent Black-lite version???
https://www.youtube.com/watch?v=AXAIXWGJr-0...MjAyNg&t=5s[/img]
gtbarnes
post Mar 8 2025, 07:28 PM
QUOTE(gtbarnes @ Mar 8 2025, 05:24 PM) *
Last chance for Monday! Secure next weekends project now! https://gtbarnes914.com/ Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Probably the most satisfying thing you can do to your 914. Very easy on the eyes from dark to lit to bright, every range in between. https://gtbarnes914.com/
I have a 'How To Install and connect the wiring and dimmer' if anyone askes me for it.
This kit came from much trial and error to achieve the best illumination for each specific gauge. The length, width and intensity of the leds is matched for each gauge. They are top quality, soldered and shrink wrapped, with the thick 3m glue on the back. You will only need the dimmer at about half brightness even with the dark lens. The result is incomparable in quality and readability to anything else. Equal brightness in each gauge and on each number without any guesswork.
You dont want to run around looking for stuff to complete your gauges. If you are going to open your gauges you surly want to do everything you can when inside.
I have really tried to make the whole thing as complete and easy as possible and the results are truly stunning, I think you will be amazed at the results you can achieve.
All of the wiring is exactly as it needs to be to install quickly and be removable quickly.
Dont pay someone $300+ to do this, do it yourself in a weekend and have the best that looks like it could been (and should have been)from the factory.
gtbarnes
post Mar 16 2025, 04:12 PM
QUOTE(gtbarnes @ Mar 8 2025, 05:28 PM) *
aAttached Image
gtbarnes
post Mar 23 2025, 07:02 PM
QUOTE(gtbarnes @ Mar 16 2025, 02:12 PM) *
aAttached Image
I am working on setting the free shipping back up on the site. If its not working yet just let me know please.
gtbarnes
post Mar 30 2025, 10:41 PM
QUOTE(gtbarnes @ Mar 23 2025, 05:02 PM) *
aAttached Image
Here is a few more pics... thanks to everybody visiting the site!
https://www.gtbarnes914.comAttached Image
gtbarnes
post Feb 14 2026, 11:53 PM
QUOTE(gtbarnes @ Mar 30 2025, 08:41 PM) *
aAttached Image
Back from the storm....this is older posts, will update
- Lo-Fi Version Time is now: 16th February 2026 - 01:19 AM
