> Engine Cutting Out Again, Severe Miss
PDXBob
post Mar 16 2025, 07:11 PM
Hi 914’ers,
This is a revival of my old post about the same engine cutting out problem on my 1975 914 (1.8L). It cuts out generally after warmed up and driven for a while. Usually happens under load, like when I’m going up a hill. Doesn’t miss on idle or when I rev it up in the driveway. Based on the work I’ve done so far I’m now thinking must be fuel related.
Here’s an (unfortunately) long list of what I’ve checked or replaced:
- new Spark Plugs and wires,
- new 123Ignition distributor, coil and distributor cap
- no vacuum leaks, all ground wires appear in contact and good shape.
- ECM wiring appears good and I’ve tried wiggling its wires to see if any faults
- Tested the TPS and it’s good, also AFM flap moves smoothly.
A couple of other interesting things- I didn’t drive it for about 2 months, and after installing new distributor it ran great for about 2 weeks. Also, on Friday it was cutting out bad, then I stopped at a store for about 1/2 hour and when I restarted and drove home the cut out had disappeared.
So, I’m now think fuel system related.
Any ideas would be greatly appreciated!
PDXBob
Bruce Hinds
post Mar 16 2025, 08:11 PM
V-8 madness
QUOTE(PDXBob @ Mar 16 2025, 06:11 PM) *
Hi 914’ers,
PDXBob
I fought a similar problem for a long time and I didn't figure it out until it got so bad it wouldn't run. Turned out to be the ignition switch. I actually put in a remote switch rather than replacing the ignition switch since I leave it with the top of a lot.
post Mar 17 2025, 05:33 AM
Very interesting, I was going to say coil related (they can become heat sensitive) but anything that causes a drop of power reaching the coil would have the same effect. Does your tach behave strangely when this is happening?
VaccaRabite
post Mar 17 2025, 05:41 AM
En Garde!
Yeah, its not as likely to be fuel. It sounds like an electric problem. Instant cut outs are almost always bad electrical somewhere in the system.
Zach
burlybryan
post Mar 17 2025, 07:54 AM
A friend had a similar issue and it was the coil. Surprisingly it was a replacement Bosch that had tested good, but would cut out under high rpms.
GregAmy
post Mar 17 2025, 08:15 AM
Similar. Even had to have it towed home once.
It was the round relays, specifically probably the one for the fuel pump.
My resolution was to remove all of the relays and take a razor blade and GENTLY pry the male quarter-split pins apart just a tad, to get better contact within the pin holes. You can feel how they sit tighter in the plate now. Small pipe cleaner to clean out any corrosion in the female pins. Added some dielectric grease and it's been perfect since.
I eventually replaced all the relays with 914 Rubber versions. If you go that way I do still recommend cleaning the female pins and some dielectric.
https://914rubber.com/black-5-pin-multi-pur...lectrical-relay
L-Jet914
post Mar 17 2025, 01:35 PM
QUOTE(GregAmy @ Mar 17 2025, 07:15 AM) *
The fuel pump for the 1.8's is powered by the dual relay that mounts to the battery tray.
PDXBob
post Mar 17 2025, 02:18 PM
QUOTE(emerygt350 @ Mar 17 2025, 06:33 AM) *
Thanks for response! No, tachometer does vary when cutting out.
PDXBob
post Mar 17 2025, 02:20 PM
QUOTE(GregAmy @ Mar 17 2025, 09:15 AM) *
Thanks. I’ll probably replace all relays. As a 1975 year car some of them may be 50 years old!
PDXBob
post Mar 17 2025, 02:23 PM
QUOTE(L-Jet914 @ Mar 17 2025, 02:35 PM) *
Yes, I hope it’s not the dual relay- kind of $$$$. Anyway to test? I may take it out, clean and see if I can test. Thanks.
Dave_Darling
post Mar 18 2025, 01:42 AM
914 Idiot
The 1.8 does not need any of the round relays to run.
I think I would start wiggling wires while the engine is running to see if any of them make it stutter or stall. Bad/loose connections or broken wires can do that.
Have you looked in your fuel tank? Debris in there can clog the pickup, then when the pump stops running it can sink back down to the bottom of the tank. (Don't use a match; have a fire extinguisher nearby!)
--DD
Artfrombama
post Mar 18 2025, 01:56 AM
Missing under a load is usually point gap too narrow (electronic, not this) or fuel starvation. Fuel filter, pinched fuel line or low fuel pressure
wonkipop
post Mar 18 2025, 02:06 AM
i agree with dd and artfrombama.
i reckon its fuel.
either a looped hose is collapsing at a bend or there is a problem at the tank.
sock in tank? even a fuel filter - dunno if you have checked the filter, maybe you have.
typically this tends to happen after you have had it running a while.
debris builds up,
the car calls for fuel under load and it all chokes up.
or alternatively a looped hose which has aged a bit collapses under demand for the fuel and strangles off supply.
Artfrombama
post Mar 19 2025, 12:15 PM
QUOTE(PDXBob @ Mar 17 2025, 03:23 PM) *
Send it to me, I'll stick it in my car and give it a shot N/C. PM me
ClayPerrine
post Mar 20 2025, 03:22 PM
You may think this silly, but pull the passenger seat and see if the seat belt interlock crap is still there. It has a thin black wire that goes from the unfused side of fuse #8 to the interlock logic relay. If that wire is out of the connector and bouncing on the floor, it will cause the ignition to cut out. The symptoms you describe fit that problem.
It could also be an issue with the seat belt interlock logic relay itself. Either way, the solution is to drop the fuse block and cut the wire free from fuse #8. Then it can't short out.
PDXBob
post Mar 27 2025, 07:48 PM
QUOTE(ClayPerrine @ Mar 20 2025, 04:22 PM) *
Thanks Clay. I never considered seat belt interlock “crap”. One more thing to add to my list.
PDXBob
post Mar 27 2025, 08:06 PM
I’ve been working on my bad cut-out/miss, and am redoing a few of the ground wires that seemed a little frayed. One thing I’ve noticed is that F.I. Wiring is “brittle”, and not the good kind of brittle, as in (peanut) brittle.
As some have suggested, I’ve tried jiggling FI wires while idling, and it doesn’t cut out then, but this harness may be on its last legs- 50 years old. May have to inquire about cost of good used FI harness. Hate to just continue to replace parts without knowing the root cause of my cut-out/miss problem though.
I still need to check out a lot of things you all have suggested.
Thanks again for all of your ideas!
PDXBob
mgphoto
post Mar 28 2025, 10:00 AM
What I personally found is that the issue is electrical, fuel or ignition, if the engine back fires then it’s ignition as fuel is still being introduced into the cylinders if there isn’t any back fire than it’s fuel interruption. Most often it’s something simple like a loose connection, you mentioned that the engine ran fine after you installed the 123 dizzy, that is a clue. Good luck.
post Mar 28 2025, 10:23 AM
QUOTE(mgphoto @ Mar 28 2025, 10:00 AM) *
There is an exception to this... the combination of the two. When your TPS malfunctions the ECU cuts all injectors, so an electrical issue resulting in a fuel issue and no backfire...
- Lo-Fi Version Time is now: 9th May 2025 - 01:07 AM
