> 912 4 speed trans $1500, covert to 914
Al Meredith
post Mar 17 2025, 12:34 PM
I just finished rebuilding a 912 4 speed transmission # 902/0 with the proper gears A,H,Q,X . This is an early aluminum case and I believe it can be converted to a 914 side shifter. I have heard that the 4 speed was preferred for high torque ( V8) conversion because of the now first gear is not hung out to the rear of the mid plate bearing where it has no support. Attached Image Attached ImageAttached ImageAttached Image
davep
post Mar 17 2025, 02:04 PM
914 Historian
Group: Benefactors
Region Association: Canada
I do not see how it can be converted to 914 use. As you say, it is an aluminum case and therefore the magnesium 914 end cap cannot be properly attached AFAIK. If it was a mag case 901/902, then yes it would be possible with some modifications.
post Mar 17 2025, 02:31 PM
QUOTE(davep @ Mar 17 2025, 04:04 PM) *
Why not just sell it to the SWB guys. 912 or 911.
Al Meredith
post Mar 17 2025, 03:46 PM
QUOTE(mepstein @ Mar 17 2025, 01:31 PM) *
I will but like to offer to my 914 friends first if no action here I'll go to 912BBS or other sites.
ClayPerrine
post Mar 18 2025, 07:35 AM
Also, when you convert a 914 to a 4 speed for use with a V-8, you get a taller 1st gear. The 901 factory 4 speed has an A first gear. If you convert a 5 speed, you get a F first gear. The V-8 likes the taller first gear.
post Mar 18 2025, 06:34 PM
A stock 912 transmission will give you four speeds in reverse and one forward.
Unless you run it upside down or put the ring gear on the other side, is that even possible or recommended?
- Lo-Fi Version Time is now: 8th May 2025 - 10:22 PM
