> Free Koni Reds
morehills
post Mar 17 2025, 04:17 PM
Can anyone use these. They worked fine when I took them off. Pay shipping. Not sure what the springs are. Not sure what the shocks are. But I don't wan't them to rot in my barn. If you want them, LMK and pay shipping. PM me details.
post Mar 18 2025, 06:55 AM
Edit: I think i see the adjustment on top that makes them the gas filled modern type.
If the tab turns about 2-3/4 turns they should be good.
Springs look stock. If you measure the diameter of the thickness of the coil you can tell if they are stock.
You have to remove the springs to test the shocks for smooth travel and adjustment function. The shock type is marked on the bottom. Special D is the old oil filled. If they have the small adjustment tab at the top they are newer gas filled. I find more than half of the old Konis are shot.
The hardware is often more needed than the shock.
The price is right. I had several tested pairs and could not sell them for $50
- Lo-Fi Version Time is now: 8th May 2025 - 10:13 PM
