> Odometer inop
JOEPROPER
post Apr 26 2025, 10:18 AM
The answer is "no" unless you ask...
My speedometer works fine, but the odometer stopped working. Should I try to repair or replace it? I haven't done any research yet, so I'm not certain what it would cost
Any thoughts? BTW. 1975 2.0L.
Aerostatwv
post Apr 26 2025, 10:28 AM
https://instrumentclusters.com/ did my speedo 3 years ago that had the exact same issue as yours... 50 year old grease turns to a hard putty like substance. $350 and they pay shipping in both directions. One year warranty and they polish the lens and have a quick turnaround.
There are others that repair them but these folks did right by me..
Cheers,
Chris
post Apr 26 2025, 10:29 AM
It’s a feature - it ensures these cars stay low mileage
JOEPROPER
post Apr 26 2025, 11:11 AM
QUOTE(Aerostatwv @ Apr 26 2025, 12:28 PM) *
Cheers,
Chris
Thanks for the info. Need to move onto the Classified section for a used one. Thanks again.
joeproper
dtmehall
post Apr 26 2025, 12:10 PM
i have used these guys in the past. they do good work.
https://www.nhspeedometer.com/
Ron914
post Apr 26 2025, 12:11 PM
QUOTE(Superhawk996 @ Apr 26 2025, 11:29 AM) *
post Apr 26 2025, 02:01 PM
This is the easiest do it yourself repair on the car. Anybody remember where the step by step instructions are?
rfinegan
post Apr 26 2025, 04:38 PM
likely its a drive area that needs replace..it is not to hard to odd yourself, i have done 2 914 and a 928(that was a big job).but made a few bucks and see the owner a bunch or CA$$
they last almost forever ...but NEVER reset your odometer while driving. they seem to stop working shortly after doing this
914sgofast2
post Apr 26 2025, 04:50 PM
There seem to be 2 different but related reasons that the odometer stops working, even though the speedometer still works. The first is that the main drive gear inside the speedometer is no longer tightly fastened to the metal shaft it is pressed onto. Pelican Parts has a tutorial on how to fix a loose speedometer drive gear.
The second problem that I have experienced on at least three (3) speedometers is that the pot metal pedestal inside the speedometer body that supports the metal shaft the drive gear is attached onto gets worn oval. The ovality in the support pedestal allows the shaft to move far enough that the drive gear no longer makes constant mesh contact with the geared number drums which record the total miles driven. The only fix for this second type of problem is to look for a good working used speedometer or to send your speedometer away to a speedometer repair shop.
- Lo-Fi Version Time is now: 9th May 2025 - 03:23 AM
