> Dellorto blues, I've reached my limit
barefoot
post Jun 8 2025, 06:39 PM
For several years after After I but it all back together the car's been running fine, had to clean one carb once and that worked fine. Now it's getting worse won't idle, it just dies after I let off the throttle. Runs strong at higher loads but very poor at idle & low load. I've cleaned the carbs enough that think I could do it blindfolded. I know the points dwell is OK and I haven't touched the advance. Using a heat gun i can measure header pipe temps just before muffler and one cylinder on each bank is way lower temperature than it's neighbor after holding the rpm's just above idle speed.
Think I'll pull the carbs off and do a compression check just to rule out one thing.
Can't even do a synchronize without a smooth idle.
Is there someone in our group who is Dell 40 expert so i can send carbs off to ???
I've prided myself as a competent mechanic but this has got me on the edge.
Not having fun anymore (IMG:style_emoticons/default/headbang.gif)
Barefoot
Posts in this topic
barefoot   Dellorto blues   Jun 8 2025, 06:39 PM
Osnabruck914   I run Dells on my 2.0L. Are you sure the O-rings ...   Jun 8 2025, 08:04 PM
fixer34   Not familiar with carbs on a -4, but something doe...   Jun 8 2025, 08:34 PM
infraredcalvin   Not familiar with carbs on a -4, but something do...   Jun 9 2025, 09:09 PM
cgnj   @Barefoot I am a Dellorto fanboy. Here are my que...   Jun 8 2025, 11:45 PM
barefoot   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Jun 9 2025, 04:55 AM
cgnj   @Barefoot I will PM my contact info to you and so...   Jun 9 2025, 10:50 AM
Osnabruck914   Another common culprit could be air leakage where ...   Jun 9 2025, 12:46 PM
porschetub   Another common culprit could be air leakage where...   Jun 10 2025, 11:07 PM
Literati914   I know a lot of guys would be against this.. but I...   Jun 9 2025, 12:49 PM
Osnabruck914   I know a lot of guys would be against this.. but ...   Jun 9 2025, 03:25 PM
rhodyguy   Are the plugs wet? Have you checked plug wires for...   Jun 9 2025, 06:53 PM
cgnj   @litertia914 Empi D 36,40,45. There were some revi...   Jun 9 2025, 08:36 PM
L-Jet914   For several years after After I but it all back t...   Jun 9 2025, 08:48 PM
barefoot   Update: tried driving it just down the street and...   Jun 10 2025, 06:49 AM
Superhawk996   Apparently I’ve got an edit / operator error pro...   Jun 10 2025, 03:29 PM
Superhawk996   Oops - duplicate :(   Jun 10 2025, 03:33 PM
Superhawk996   FWIW - I’ve had issues in the past that requires...   Jun 10 2025, 03:32 PM
dr914@autoatlanta.com   the most competent mechanic in the world cannot de...   Jun 11 2025, 03:16 PM
Osnabruck914   [quote name='dr914@autoatlanta.com' date=...   Jun 12 2025, 10:27 AM
porschetub   [quote name='dr914@autoatlanta.com' date=...   Jun 13 2025, 01:23 PM
anderssj   :agree: I’ve been running Dell’s (2xDRLA-40)...   Jun 12 2025, 02:54 PM
cgnj   @Osnabruck914 [b]@[url=http://www.914world.com/b...   Jun 12 2025, 07:22 PM
nditiz1   This is the first time I think I have ever heard s...   Jun 12 2025, 10:05 PM
930cabman   my $5. says it's a clogged idle jet, one ...   Jun 13 2025, 10:35 AM
- Lo-Fi Version Time is now: 9th March 2026 - 10:50 PM
