914rrr |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,971 Joined: 1-July 03 From: Knoxville, TN Member No.: 874 Region Association: South East States ![]() |
I found a large stash or 914 parts. The owner of said 914 parts is primarily into 911's and 356's and needs room in his warehouse. He wants to get rid of everything 914 related but I think his price for the entire lot is overly optimistic, especially since the 914 stuff is intertwined with all his other P Car stuff and the days/weeks worth of my time to sort through it all, move it store it, etc.
Most of the stuff is "OK". For example: Qty. 20 - 1.7 or 1.8 heads (a couple were rebuilt) 2 or 3 tail shifter trans 2 pairs of late doors (appear to be fairly rust free) 2 late engine lids 2 or 3 Targa tops 2 or 3 used rear bumper pre 75-76, 1 has louvers punched in the license plate area 1 dash that was somehow recovered in a veined vinyl (not a bad job but is pulling away on the bottom of the pod 3 or 4 1.8 air box tops and flappers 1 used Bursch? muffler 2 pairs of 914 seats with non stock velour inserts (one with matching reddish "radwood-ish" door panels 1 stock front valence 1 or 2 stock rear valence 1 W engine block, possibly NOS but he might keep Bunch or used signal and side marker lenses, 1 US rear lens Stack of repro door jamb metal, maybe 6 2 fair under dash pads Stack of used fair to good door panels Bunch of door locks, latches, plates Ton of "smalls" etc. etc. etc. The seller was open to taking payments. I'm thinking more like "buy as you go". I'm open to ideas, partners, group buys, etc. |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,169 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
If I was going to have to spend a day (or more) and do work for that parts list, a couple hundred bucks would be my max.
Otherwise, he’s charging you to to paint his fence |
Montreal914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,949 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California ![]() ![]() |
Agreed, I don't see any high value items in that list other than potentially the 2 liter heads, the core tail shifts gearboxes and maybe 1.8 FI parts. Door handles if chrome is nice and no broken tabs? Even this "high value" lot is worth low hundreds.
A lot of effort for a few dollars in return. |
914rrr |
Agreed, I don't see any high value items in that list other than potentially the 2 liter heads, the core tail shifts gearboxes and maybe 1.8 FI parts. Door handles if chrome is nice and no broken tabs? Even this "high value" lot is worth low hundreds. A lot of effort for a few dollars in return. No 2.0 heads, already checked. Ouch, tough crowd, LOL! |
Al Meredith |
Senior Member ![]() ![]() ![]() Group: Members Posts: 980 Joined: 4-November 04 From: Atlanta, ga Member No.: 3,061 ![]() |
Agreed, I don't see any high value items in that list other than potentially the 2 liter heads, the core tail shifts gearboxes and maybe 1.8 FI parts. Door handles if chrome is nice and no broken tabs? Even this "high value" lot is worth low hundreds. A lot of effort for a few dollars in return. Hey Rob its Al in Atlanta , I could use two 1.8 L heads if they are rebuilt. Are you able to look at the heads to see? |
914rrr |
Agreed, I don't see any high value items in that list other than potentially the 2 liter heads, the core tail shifts gearboxes and maybe 1.8 FI parts. Door handles if chrome is nice and no broken tabs? Even this "high value" lot is worth low hundreds. A lot of effort for a few dollars in return. Hey Rob its Al in Atlanta , I could use two 1.8 L heads if they are rebuilt. Are you able to look at the heads to see? Sure Al, what markings / features denote a 1.8 head vs 1.7? |
914rrr |
I'm really curious, who does / did a 914 vinyl dash recover / overlay with an elephant hide-ish vinyl fabric that was somehow glued / molded over the exiting OE molded vinyl?
It was in a box like it came from a business. Whoever did it did a pretty good job as there were no wrinkles I could see and the vinyl fabric used was pretty thick. The only drawback was the vinyl fabric overlay had shrunk / pulled up a bit from the bottom of the pod area nearest the windshield. |
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,300 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
1.8 heads 022
1.7 heads 021 |
Jack Standz |
Senior Member ![]() ![]() ![]() Group: Members Posts: 575 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None ![]() ![]() |
There is some value there (i.e. the doors, valences depending what they are and condition, etc.).
The replacement "W" engine case, even though NOS might not be worth all that much anyway. It's been reported that those are the weakest of all the Type IV/914 cases & you're probably better off starting with a rebuildable used one. |
mepstein |
I'm really curious, who does / did a 914 vinyl dash recover / overlay with an elephant hide-ish vinyl fabric that was somehow glued / molded over the exiting OE molded vinyl? It was in a box like it came from a business. Whoever did it did a pretty good job as there were no wrinkles I could see and the vinyl fabric used was pretty thick. The only drawback was the vinyl fabric overlay had shrunk / pulled up a bit from the bottom of the pod area nearest the windshield. Are you sure it’s not a thin plastic cover. The description sounds just like the better plastic overlay. Looks pretty realistic from 3 feet. You can see the edges around the gauges. |
rjames |
I'm made of metal ![]() ![]() ![]() ![]() Group: Members Posts: 4,394 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest ![]() ![]() |
Lots of the usual stuff in the usual condition. Many of us probably have at least one of those items collecting dust in the garage somewhere.
IMO, if you’re looking to make enough money reselling it all to make it worth your time to haul it away, he’s going have to give it you to for a very low price or for free. What’s your time and effort worth? |
Chris914n6 |
Jackstands are my life. ![]() ![]() ![]() ![]() Group: Members Posts: 3,507 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region ![]() |
I have a stash like that. Currently not worth the time to list pack ship for the money.
914rrr |
Lots of the usual stuff in the usual condition. Many of us probably have at least one of those items collecting dust in the garage somewhere. IMO, if you’re looking to make enough money reselling it all to make it worth your time to haul it away, he’s going have to give it you to for a very low price or for free. What’s your time and effort worth? Pretty much what I was thinking offer wise for the lot. I could see days / weeks sorting through all this 914 stuff. Even at $5/hr. that is a fairly hefty investment over and above the value of the parts AND I need to clear out space to put them in. He did give me a rear trunk push lock assembly for free that I needed. (IMG:style_emoticons/default/biggrin.gif) I'm likely going to try cherry picking the stuff I really need and try to assist him in selling some of the other stuff. I don't mind hanging out at his shop as he has some cool rides and projects like a Toyota Mega Cruiser (H1 look alike) and a 60 Series Land Cruiser he's restoring for customers, a 356 outlaw, a full race widebody 400 HP VW Rabbit, an 911 RSR tribute, among others. |
Front yard mechanic |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,387 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None ![]() ![]() |
I agree with most maybe if he threw in a couple 6 cases it might be worth pursuing
carr914 |
Racer from Birth ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 128,285 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States ![]() ![]() |
I've thrown out parts like that before
Literati914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,113 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region ![]() |
Puebloswatcop |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,677 Joined: 27-December 14 From: Mineola, Texas Member No.: 18,258 Region Association: Southwest Region ![]() |
I could use a drivers side door, if its rust free and not all banged up.
aharder |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,828 Joined: 6-September 11 From: Dallas Texas Member No.: 13,524 Region Association: Southwest Region ![]() ![]() |
I would also be interested in a set of 1.8 heads
JOEPROPER |
The answer is "no" unless you ask... ![]() ![]() ![]() Group: Members Posts: 1,208 Joined: 21-November 15 From: White Plains New York Member No.: 19,387 Region Association: North East States ![]() ![]() |
May be prohibitive, but I would be interested in an targa top if its really nice shape. 1975.
914rrr |
Looks like the seller is sticking to an "All or Nothing" stance. I even offered to help him ID the heads he has to see if any of them were 1.8. No dice. Sorry.
Lo-Fi Version | Time is now: 23rd October 2025 - 03:29 PM |
