> Rear Tires Clearance Question
Osnabruck914
post Aug 29 2025, 12:02 PM
'74 914 2.0
Tires 185 65 R15
Question:
The rear camber on my rear wheels measures equal, yet when I reach up in the wheel well and try to feel the space between the tire and the side of the trunk body, it is not equal. On the driver side I can get my hand into the space up to my knuckles, but on the passenger side only to the 2nd joint of my fingers.
Is the body of the trunk non-symmetrical by design, or is something else going on here? Input appreciated.
Osnabruck914
Jamie
post Aug 29 2025, 12:23 PM
QUOTE(Osnabruck914 @ Aug 29 2025, 10:02 AM) *
'74 914 2.0
Tires 185 65 R15
Question:
Osnabruck914
I've heard many times about the irregularities of rear wheel well fitment on teeners, and know I have a slight variation in clearance between sides on my 73 all original teener. I've run several sets of 205x65x15" tires on 5.5"steel wheels over the years, and they fit with no fender pulling required. (IMG:style_emoticons/default/driving.gif)
914sgofast2
post Aug 29 2025, 12:45 PM
The 914 bodies were “coach built” by Karmann craftsmen. They were not mass produced like VW Beetles. The variations were normal and oftentimes made worse when there were body repairs done. These were considered affordable, cheap sports cars for many years, so body repairs were performed accordingly.
NARP74
post Aug 29 2025, 01:10 PM
Hans was a better builder than Fritz. It depends which one you have.
Mine is a Fritz...
Osnabruck914
post Aug 29 2025, 02:26 PM
Let me be clear, I am reaching around the top back of the tire and feeling the space between there and the body. I am not referring to the space between the tire and the fender.
Does that help/change your analysis, all? Thanks.
Geezer914
post Aug 29 2025, 03:58 PM
Geezer914
Mine is a 75 and the right side has about 1/2" more clearance than the left.
dtmehall
post Aug 29 2025, 04:33 PM
i have similar differences on my 73, and it was never in an accident. i guess hans built mine!
wonkipop
post Aug 29 2025, 04:51 PM
they are asymmetrical across the whole back region from the get go.
in part it could have even been transfer of dimensions for tooling from the clay model.
which is how they did it back then. side to side final contours could be slightly different.
not resolved with exactness until computers came along. but does not explain the wandering about in 914s.
i suspect its to do with difficulties in manufacture.
and not because karmann was some kind of "craft" or kraftwerk set up.
they weren't. not by that point in time. they had body presses etc equal to anything VW had at wolfsburg or porsche had at reuter. they had spot welders. it was all well up tod date and not really hand built as we might imagine that to mean. they had jigs to accurately position body parts for the assembly of the shell. i have never seen a photo of a 914 on its body shell jig but i have seen images of the 912 body on its jig being manufactured at karmann.
its a serious affair.
i think it might have had something to do with that dirty big hole in the middle of the car where the engine went and adjacent to that another hole where there was no roof - that only a mid engined design open car involves. they just got out of wack or the jig could not hold them precisely enough as they worked up from key positioning points on the jig.
they did use an unusual number of small panels welded together to make the whole rear of the car instead of one single pressing. that could very well have something to do with it. and stresses induced during fitment and welding together. whatever it was it plagued all the bodies - but not to any inherently insurmountable degree.
wonkipop
post Aug 29 2025, 05:00 PM
912 on its body shell jig at karmann.
i imagine the 914 is similar since it comes after this.
this 912 set up is from sometime between 65/66 and 69 when karmann was building all the USA bound 912s and some 911 body shells for porsche.
(as an aside does that make those 912s/911s not a real porsche?, or the 914/6 a VW? (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) ).
in this particular photo i think they have dropped the body down on to a jig that fixes to key suspension points and they are check measuring key points on the upper body of the car. but to begin with the body would have been on similar base plate jigs for assembly.
there were also similar rigid jigs where the full mechanicals were arranged and then moved across and lifted to mate with the bodies which were on overhead cradles. i guess all that really mattered was the key positioning points of suspension attachments in space in the XYZ co-ordinate system with some inbuilt tolerance. probably in the order of 10 to 20mm + or -.
the 10 mm or so is what you can feel in your knuckles one side and only finger tips on the other. its allowed to be out by that much side to side.
Osnabruck914
post Aug 29 2025, 05:10 PM
Great. Sounds like it is normal. I will not lose anymore sleep about it.
THANKS ALL!
Osnabruck914
- Lo-Fi Version Time is now: 29th August 2025 - 07:10 PM
