914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,244 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
Almost impossible to find. Lets you use for 2.0L rocker arms AFTER they have been machined.
paypal.me/markheard1 Attached thumbnail(s) ![]() |
cgnj |
Senior Member ![]() ![]() ![]() Group: Members Posts: 684 Joined: 6-March 03 From: Medford, NJ Member No.: 403 Region Association: None ![]() ![]() |
I use these on one of my motors. Side bonus is they are allen head and much easier to adjust valves.
Fazasport |
Newbie ![]() Group: Members Posts: 9 Joined: 7-November 23 From: Tallahassee FL Member No.: 27,713 Region Association: South East States ![]() |
914Sixer |
The thickness of the arm has to be cut down. Have a set done, will get pictures.
914ltd |
Member ![]() ![]() Group: Members Posts: 245 Joined: 18-April 03 From: Peoria, IL Member No.: 581 Region Association: None ![]() ![]() |
I made a jig to hold 4 rockers. I used a belt sander to cut the bottom side down to 11.5mm for 8mm 911 wobble feet.
Mark might be able to check this dimension for the 10mm wobbles. A 24 or 36 grit belt removes the metal relatively quickly. Brad Attached thumbnail(s) ![]() ![]() |
914werke |
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,393 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest ![]() ![]() |
Nice.
Keep in mind depending on your geometry if using the OE covers they may need to be "massaged" to avoid the top of the adjuster tapping the cover |
914Sixer |
Tabari did these differently. He took a little off the bottom and beveled out the center.
Attached thumbnail(s) ![]() ![]() ![]() |
zerliq |
Newbie ![]() Group: Members Posts: 5 Joined: 16-June 11 From: colorado Member No.: 13,204 Region Association: None ![]() |
Lo-Fi Version | Time is now: 17th September 2025 - 12:27 AM |
