hawirick |
Newbie ![]() Group: Members Posts: 4 Joined: 16-July 24 From: Hawi, Hawaii Member No.: 28,239 Region Association: Hawaii ![]() |
This is my first post on this forum, so forgive me if the issue has been covered before. I couldn't find it using the "search" feature. Probably common knowledge in the 914 community. Recently purchased a decent 1975 1.8 here on Hawaii island. There have been a number of small issues that I've had to deal with, but this one has me stumped. The turn signals only operate when the parking brake is engaged. Any ideas?
Spoke |
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,248 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None ![]() ![]() |
The 914 uses the flasher relay to flash the brake warning light when the ebrake is active. Couple of questions: With the ebrake active and brake warning light flashing, do the exterior turnsignal bulbs flash too? Do the exterior turnsignal bulbs flash when the 4way or hazard switch is pulled? Do the correct left or right exterior turnsignal bulbs flash when the car is running and the turnsignal stalk is left or right? |
Highland |
Senior Member ![]() ![]() ![]() Group: Members Posts: 552 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California ![]() |
I had weird things happening with my turn signal and culprit was wrong bulb. I had a single filament where I should have had a dual filament.
Probably not the solution, but easy check. |
jim_hoyland |
Get that VIN ? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,875 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California ![]() ![]() |
When I had a somewhat similar problem it turned out the TS switch had some sort of short and caused anomalies in the turn signal lights. Took a long time to narrow it down to the switch.
The TS switch is easy to test on the bench. |
hawirick |
Thank you for the prompt replies!
Answers to Spoke's questions: Yes, the exterior turn signals operate but not in unison with the ebrake light. Only as directed by the turn signal switch. Yes, the 4-way light work normally at all times. With the car running or not, the turn signals work only when the parking brake is operated (the switch on the brake handle operated). there is one additional symptom that I forgot to mention. When the parking brake is operated, there is a loud buzzing coming from under the dash, possibly from the flasher relay, which I believe is on the back of the fuse panel. |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,257 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
Where'd you get the car? I don't think Gunner sold any of his. Was this from Punawele St.? I know there was a copper 75 living there with at least one parts car.
Sounds like a wiring or grounding issue. Do you have any manuals for the car? Wiring diagrams would be very good to have. Jeff Bowlsby's Tech Notebook page has labeled drawings of the turn signal buckets showing what wire goes where. That's a good place to start. https://bowlsby.net/914/Classic/TechNotebook.htm --DD |
hawirick |
Where'd you get the car? I don't think Gunner sold any of his. Was this from Punawele St.? I know there was a copper 75 living there with at least one parts car. Sounds like a wiring or grounding issue. Do you have any manuals for the car? Wiring diagrams would be very good to have. Jeff Bowlsby's Tech Notebook page has labeled drawings of the turn signal buckets showing what wire goes where. That's a good place to start. https://bowlsby.net/914/Classic/TechNotebook.htm --DD |
hawirick |
Got the car in Hilo, from a guy named Donn. He got it fairly recently from a guy in Waikoloa. I'm not sure but the car was possibly in Huna Maui prior to that.. No, I don't think Gunner is ready to sell any of his many Porsches...
This one is currently Guards Red. Originally Mangala Red. No discernable rust! |
Dave_Darling |
Very nice! Glad to hear of another 914 on island!
--DD |
Lo-Fi Version | Time is now: 17th September 2025 - 12:24 AM |
