> Seized Piston Rings, Best Method to Remove Piston
SteveNMaine
post Oct 13 2025, 12:06 PM
I recently started a rebuild on a seized 1.8. I found that moisture has seized the rings and the exhaust valve on #2 cylinder. The piston is seized near the top of the exhaust stroke.
Any suggestions to free up the piston rings? I have heated the top of the piston, used penetrating oil, tapped with a mallet, etc. So far, no joy.
Ishley
post Oct 13 2025, 12:45 PM
You may have to crack the case open… unbolt all the rods and slide the whole thing out… piston, rod and barrel. Depending where the crank sits… the rod bolts might be a tough reach. Likely it’s all toast…so from there you might just surrender and buy all new inners. If you really have to get the piston out… use a press. That’s what I’ve had to do with a motor cycle once. You might get lucky. Good luck!
Artfrombama
post Oct 13 2025, 01:06 PM
Artfrombama
Add some penetrating oil to that cylinder, put the car in 3rd and rock the car fwd/backward.
Don't pry on the fan blades, they break easily
SteveNMaine
post Oct 13 2025, 01:24 PM
QUOTE(Artfrombama @ Oct 13 2025, 01:06 PM) *
Engine is on an engine stand with that head removed.
Artfrombama
post Oct 13 2025, 02:47 PM
Artfrombama
QUOTE(SteveNMaine @ Oct 13 2025, 02:24 PM) *
OK...
Fashion a pusher to attach to the head studs and push the piston out of the cylinder. IE., like a harmonic balancer remover
- Lo-Fi Version Time is now: 13th October 2025 - 05:02 PM
