| oakdalecurtis |
Oct 17 2025, 05:34 PM
Oakdalecurtis ![]() ![]() ![]() Group: Members Posts: 1,391 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California
76 2.0 fi stock, 130,000 miles
Lost compression on 1 cylinder. Engine out, heads off, valve seat dropped. Shop said amazing engine hadn’t seized up. Look at pic of valve seat, they had never seen the melted look on the left side of the valve port. Any thoughts on that? Pistons had valve marks, cam was done, crank was 3 thousands out out round, bearings shot. We’re going to replace everthing other than the block (still good). New cylinders and heads, pistons, crankshaft, cam, bearings, clean the injectors, polish all the tin and anything else it might need. Engine should be like new when finished! |
| oakdalecurtis |
Dec 16 2025, 06:36 PM
| trojanhorsepower |
Dec 16 2025, 06:48 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,011 Joined: 21-September 03 From: Marion, NC Member No.: 1,179 Region Association: None |
Looks good. What oil pump and heads did you use?
Dec 16 2025, 07:15 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,375 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
Looks good. What oil pump and heads did you use? (IMG:style_emoticons/default/agree.gif) , also P&C's, crank, cam, |
| oakdalecurtis |
Dec 17 2025, 05:35 AM
Lo-Fi Version | Time is now: 18th December 2025 - 01:14 AM |
