> Trailing Arm Mounting Holes
DennisV
post Oct 20 2025, 06:04 AM
I assume something is meant to mount in the holes found on the rear trailing arm tabs. Can someone clarify or offer a picture?
It seems like a good place for a parking brake cable clamp, but I'm not seeing anything in the parts catalog or my photos from before disassembly.
Thank you.
The photo is from engine bay looking out toward passenger rear wheel.
fixer34
post Oct 20 2025, 01:28 PM
QUOTE(DennisV @ Oct 20 2025, 07:04 AM) *
Thank you.
I just went and looked at mine, the only bracket anywhere near that position is for the caliper parking brake cable and it looks quite different. Also, what is that shaft in the picture that appears to go to the trailing arm?
Cfletch
post Oct 20 2025, 02:59 PM
QUOTE(fixer34 @ Oct 20 2025, 12:28 PM) *
Thank you.
I am assuming you mean the e brake cable? That mounts into the hole on the trailing arm, or are you looking at the hard line going to the brake caliper?
post Oct 20 2025, 03:26 PM
I could be wrong, but I do not recall seeing a bracket like that under my car. (IMG:style_emoticons/default/beerchug.gif)
Cfletch
post Oct 20 2025, 03:43 PM
QUOTE(Cairo94507 @ Oct 20 2025, 02:26 PM) *
I agree with you, I do not have one on my passenger side, but do have something similar but with just 1 hole on my driver side arm.
trojanhorsepower
post Oct 20 2025, 04:02 PM
Ive been all up in my trailing arms lately and nothing like that on mine.
brant
post Oct 20 2025, 04:57 PM
The six had one extra bracket to hold an oil line
Don’t think that is it
That looks home made. From previous owner I assume
post Oct 20 2025, 05:51 PM
QUOTE(brant @ Oct 20 2025, 06:57 PM) *
But the six bracket was on the body. This is just some random bracket. Cut it off, grind it smooth and paint it over.
DennisV
post Oct 20 2025, 06:27 PM
Thanks for taking a look. The "shaft" is the hard brake line to the caliper.
I have something similar on the drivers side.
This is a 1970 914-6 if it matters.
post Oct 20 2025, 11:30 PM
Interesting... (IMG:style_emoticons/default/popcorn[1].gif)
post Oct 21 2025, 12:30 AM
keeps e brake cable off of header..
Nana's_914
post Jul 25 2026, 07:07 PM
Found an underside photo of a 914-6 with the brake cable attached to that trailing arm tab. My '74 does not have the tabs on the trailing arms. Anyone have the tab dimensions to help replicate them? Length, width, hole location?
(IMG:http://www.914world.com/bbs2/uploads_offsite/goldenbarngarage.com-7100-1785020328.1.jpg)
https://goldenbarngarage.com/wp-content/upl...15-1536x864.jpg
- Lo-Fi Version Time is now: 26th July 2026 - 01:43 PM
