densible1 |
Newbie ![]() Group: Members Posts: 47 Joined: 5-April 22 From: Hermosa Beach Member No.: 26,444 Region Association: Southern California ![]() |
Just reinstalled my type 4 engine back into car everything wired up as before, upon initial start engine fired right up pretty effortlessly and continued to do so after several starts starter motor kicks in and , a HiTorque IMF, it actuates solenoid and motor spins right up. After bout 1/2 dozen starts the starter only activates the solenoid but no spin. I can hear the solenoid engaging. This is an old starter but haven't had problems before the engine re-install. I removed starter and bench tested with 12 volt leads and jumper cable on solenoid and it engages and spins readily. What's going on?
burton73 |
Senior member, and old dude ![]() ![]() ![]() ![]() Group: Members Posts: 3,897 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California ![]() ![]() |
Just reinstalled my type 4 engine back into car everything wired up as before, upon initial start engine fired right up pretty effortlessly and continued to do so after several starts starter motor kicks in and , a HiTorque IMF, it actuates solenoid and motor spins right up. After bout 1/2 dozen starts the starter only activates the solenoid but no spin. I can hear the solenoid engaging. This is an old starter but haven't had problems before the engine re-install. I removed starter and bench tested with 12 volt leads and jumper cable on solenoid and it engages and spins readily. What's going on? Mark, You also told me that you let the started cool and that did not make any difference Shout out to @bdstone914 what do you think? Best Bob B (IMG:style_emoticons/default/driving-girl.gif) (IMG:style_emoticons/default/driving-girl.gif) (IMG:style_emoticons/default/driving-girl.gif) (IMG:style_emoticons/default/driving-girl.gif) (IMG:style_emoticons/default/driving-girl.gif) (IMG:style_emoticons/default/driving-girl.gif) (IMG:style_emoticons/default/driving-girl.gif) |
densible1 |
That’s right the starter never seemed to get hot at all
Lockwodo |
Member ![]() ![]() Group: Members Posts: 237 Joined: 23-December 21 From: Santa Cruz, Californnia Member No.: 26,193 Region Association: Northern California ![]() ![]() |
Ground problem or defective battery cable? And of course make sure the battery is fully charged and passes a load test.
densible1 |
Battery putting out 14 volts. Will test in car like I did bench test see if it spins up
emerygt350 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,338 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States ![]() |
I would bet on a ground issue. Run an extra ground from the battery negative to the fan shroud. If that helps than you know what's up
fixer34 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,349 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest ![]() ![]() |
Chassis ground strap to transmission?
densible1 |
Yep
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,153 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
densible1 |
will test that in the morning. Think the starter actually is good , ran very nicely on the bench.
porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,944 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
will test that in the morning. Think the starter actually is good , ran very nicely on the bench. yes but a bench test is fine but there is no load on the starter, do your connections first and see what happens after a bad result go back to the starter ,cheers. |
Lockwodo |
Battery putting out 14 volts. Will test in car like I did bench test see if it spins up Voltage of fully charged battery measured at the posts (not the clamps) with engine not running should be ~12.7v. A lower voltage means the battery is partially discharged, for example, a reading of ~12.3v means the battery is 50% discharged. Your reading of 14v would make sense with engine running and is what the alternator is putting out, not the battery. More here: https://ratwell.com/technical/ChargingSystem.html |
Root_Werks |
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,834 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest ![]() ![]() |
Can you rotate the engine by hand?
And I second or third checking ground from trans to body and battery to body. |
Lo-Fi Version | Time is now: 23rd October 2025 - 03:28 PM |
