> WTB Lower Dashpad Interior Screw Cover Caps
JamesJ
post Oct 26 2025, 04:33 PM
Looking for the caps that cover the screws on each side of the lower dash pad, or if someone has used a McMaster-Carr part number that does the same thing, that would work. Looking for 4 of these.
Thanks.
post Oct 26 2025, 05:22 PM
914rubber should have them.
JamesJ
post Oct 26 2025, 06:59 PM
QUOTE(mepstein @ Oct 26 2025, 04:22 PM) *
I could be wrong, but I think the 914Rubber ones are too small for the lower dash.
post Oct 26 2025, 07:12 PM
QUOTE(JamesJ @ Oct 26 2025, 08:59 PM) *
I believe they make two sizes. Call them if it’s not on their site. Porsche might sell them.
JamesJ
post Oct 27 2025, 10:13 AM
914Rubber and AA don't have them...not sure if Porsche does. Next time I'm at the dealership I'll ask. Good used ones would be fine if anyone has a pair or two.
post Oct 30 2025, 06:44 AM
I’d like some too… (IMG:style_emoticons/default/smile.gif)
GeorgeKopf
post Oct 30 2025, 07:36 AM
Thingiverse has this Targa Trim Button. If this is the same as the bolster trim buttons, I can print some for you.
If that doesn't work, then if somebody sends me the dimensions and a few pictures, I can design and and print them.
George
JamesJ
post Oct 30 2025, 09:09 PM
QUOTE(GeorgeKopf @ Oct 30 2025, 06:36 AM) *
George
@dr914@autoatlanta.com
@Matty900
914ltd
post Oct 31 2025, 06:17 AM
The 2 side holes in the lower dash and the 2 drivers door pocket are a larger size. I have 4 of them them and 5 of the smaller plugs (you'll need them) that most of the other interior trim require for $30. delivered. I'll post a photo both sizes shortly. Brad
The photo shows both sizes of the screw hole plugs. The smaller appears to be 8mm and the larger is about 11mm (12?) also shown are the plugs for the bolster on the targa top and the plugs for the ski rack under the roll bar. I have all of these but a very limited number of the larger 11mm plugs.
Install these with a dab of RTV silicone.
JamesJ
post Oct 31 2025, 09:34 AM
QUOTE(914ltd @ Oct 31 2025, 05:17 AM) *
Sent PM
post Oct 31 2025, 11:02 AM
Sent PM too…
914ltd
post Nov 1 2025, 07:31 AM
QUOTE(jim_hoyland @ Oct 31 2025, 09:02 AM) *
Sent PM too…
Hi Jim
The last set of 4 larger ones go to you. I have plenty of the 8mm. Send your address. Brad
914 Limited
Brad Mayeur
1162 N. Byerly Hills Dr.
East Peoria, IL. 61611
309-868-4667
P914LTD@yahoo.com PayPal Please add $1.05
post Nov 2 2025, 01:34 PM
PM sent
GaroldShaffer
post Nov 2 2025, 09:15 PM
You bought another 914?
Group: Benefactors
@JamesJ I have one pair for sure. I will check the other parts cars after work on Monday.
DC_neun_vierzehn
post Nov 4 2025, 10:45 AM
I could use a pair of those larger plugs for the side of the dash. Never knew there were supposed to be plugs there!
1 Members: GeorgeKopf
