> Putting new injectors on the rails, What's the trick here?
DC_neun_vierzehn
post Oct 27 2025, 01:24 PM
I cannot seem to get the hose from the injector all the way up the rail. The old injectors I removed were flush at the top of the T. I tried saliva as a lubricant, but that didn't help. I tried twisting them up all the way. No dice. I tried wiggling them (twisting a little in each direction). No dice.
There must be a trick to this. I putting a lot of muscle into this w/o any kind of real success.
Should I try warming up the rubber a tad with a heat gun?
Thought I'd ask the group here before doing anything potentially stupid. Seems like the angle of the rubber elbow is making this harder than what it would be if the hose were straight.
post Oct 27 2025, 02:00 PM
The old golfers trick is mineral oil.
post Oct 27 2025, 02:43 PM
Glycerin...or KY
GregAmy
post Oct 27 2025, 02:59 PM
QUOTE(JeffBowlsby @ Oct 27 2025, 03:43 PM) *
Glycerin...or KY
Wife asked me once why I kept a bottle of "personal lubricant" in my tool box...I replied because I REALLY REALLY like my tools...it was an awkward moment. - GA
post Oct 27 2025, 03:19 PM
QUOTE(GregAmy @ Oct 27 2025, 04:59 PM) *
Glycerin...or KY
(IMG:style_emoticons/default/av-943.gif)
DC_neun_vierzehn
post Oct 27 2025, 03:37 PM
Thanks gents. The only product recommended that I have on hand is glycerine. Just gave it a shot and it worked.
I made mental notes on the other recos for future reference : )
JamesM
post Oct 27 2025, 08:05 PM
Sil-Glide
VaccaRabite
post Oct 30 2025, 03:17 PM
En Garde!
I just use engine oil out of a little handheld oil pump.
Zach
GregAmy
post Oct 30 2025, 03:30 PM
But then it stays oiled and you risk it sliding off...and oil may attack/soften rubber.
The reason to use a water-based lubricant is because it'll evaporate away, and it's safe for rubber (the "personal lubricant" part...)
DC_neun_vierzehn
post Oct 31 2025, 02:04 PM
The other trick I discovered was to bend the elbow completely straight then slide it on. Bending the elbow totally straight was the only way I could the injector hose up all the way to sit flush at the T of the rail.
Y’all probably knew that already but in case any other newbies read this thread in the future, I’m mentioning it.
post Oct 31 2025, 11:09 PM
Last trick is that you dont need heat formed elbows.
You can use some spring stock cut to length & inserted
into the elbow sections so that once bent the dont
collapse.
Dave_Darling
post Nov 4 2025, 10:55 AM
914 Idiot
IME, you don't need any of that. Just don't bend it super tight--and the fuel pressure will tend to keep the hoses from pinching shut anyway.
--DD
post Nov 4 2025, 11:00 AM
^^^ agree.
The elbow hoses are convenient but not essential. 3 in hoses (75mm) work just fine as long as you don't kink them during installation.
rjames
post Nov 4 2025, 12:59 PM
I'm made of metal
Agree that elbows aren't essential, but just using straight hoses makes working in that area and getting all the hoses attached to the rail a bit of a pain.
Becuase the J bend hoses are expensive and I wanted to make sure the right fuel hose was used, I just used straight hose and formed my own J bends via heat and inserting a spring inside.
Geezer914
post Nov 5 2025, 08:58 PM
Geezer914
Cut hose to 6" lengths . Tie the 2 ends together and heat in boiling water for 3 minutes to set the bend. Cool and untie the ends, trim to fit.
