> Compression fitting on fuel tank pipette, 6an to 5/16 hard line pipette
rfinegan
post Nov 9 2025, 08:30 AM
Any one use the compression fitted fuel line ends to adapt the pipette on the fuller tank to a PTFE 6AN fuel line?
Feed back and experience appreciated....
post Nov 9 2025, 09:20 AM
You can tap the threaed nipples on the tank1/4 FPT. Install pipe threadcto 6an. You loose the sock filter in the tank. Some VW parts suppliers have one of the nipples with 6AN fitting.
I have considered adding an externally industrial cleanable filter outside the tank.
Graydingo
post Nov 9 2025, 10:02 AM
I did this. I converted 911 Carrera hardlines to the engine bay (near the filter by cutting the pipes square and installing 6AN PTFE lines. Holds well.
rfinegan
post Nov 9 2025, 10:51 AM
great info thanks for the tips
yes the plan is a Much better pre filter and ptfe 6an lines
m14 x 1.5 is the search result fort tanks threads
this may work and clean things up for no leak/no kink lines
https://www.amazon.com/gp/product/B08SGVYFF...DH1PL&psc=1
this is wrong AI fails me again
post Nov 9 2025, 11:33 AM
Yes, did this using -6AN fittings from IIRC air-cooled.net to the tank (no longer in business) and installed PTFE fuel lines and fittings.
Also, Chris Foley of Tangerine Racing can TIG weld AN fittings on the stainless fuel lines he sells (take your pick, front or rear - we chose rear).
Edit: Actually and thinking about it some more, don't think AN fittings welded on the stainless fuel lines will pass the front/rear firewall without some opening up of the holes. Which is why we only have AN fittings on the rear of the fuel lines.
Literati914
post Nov 9 2025, 06:37 PM
I wonder if one of these would work:
https://www2.cip1.com/c26-201-209-6/
https://www2.cip1.com/jc-4560-0/
KSCarrera
post Nov 10 2025, 01:48 AM
Region Association: England
CB Performance sell 6AN (-6) and 8AN (-8) fittings that are designed exactly for this, too...
https://www.cbperformance.com/product-p/3288.htm
https://www.cbperformance.com/product-p/3289.htm
rfinegan
post Nov 10 2025, 06:18 AM
THANK YOU
I did not get the correct ends. I got the male m14 x 1.5 and not the Screw On type
this was wrong too and got the ones from CBP
jd74914
post Nov 10 2025, 10:46 AM
Its alive
QUOTE(rfinegan @ Nov 9 2025, 09:30 AM) *
Seems like you have a better path now but just in case you have future need there is only one place I know of sells these metric compression to to 37 degree adapter fittings...
FAV Fittings
FCF/MCJF/5I-8T
https://favfittings.com/instrument-fittings...onnector-jic-2/
They are a real company. (IMG:style_emoticons/default/laugh.gif) No idea on what the lead time for this kind of stuff is though.
rfinegan
post Nov 18 2025, 10:19 AM
CB Performance fittings for the Win! Perfect fit
- Lo-Fi Version Time is now: 19th November 2025 - 09:37 AM
