| Osnabruck914 |
Nov 11 2025, 01:51 PM
Member ![]() ![]() Group: Members Posts: 179 Joined: 19-December 22 From: United States Member No.: 27,038 Region Association: South East States |
According to the factory manual, you must remove the auxiliary carrier in order to have clearance to remove the steering rack. I have removed every bolt from the carrier plus the torsion bar adjusting lever arms, and I still cannot budge the carrier away from the A-arms. How is this accomplished? Urgent advice needed.
Osnabruck914 |
| Osnabruck914 |
Nov 11 2025, 06:19 PM
Nevermind. Solved my problem with a big screw driver used as a lever- carrier slid right off the bushings.
Osnabruck914 |
| sixnotfour |
Nov 11 2025, 11:09 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,030 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains
Nov 13 2025, 10:57 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 585 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None
Proof again tht sometimes you just need a bigger hammer, or in this case a bigger screwdriver (IMG:style_emoticons/default/biggrin.gif) .
Good job! (IMG:style_emoticons/default/piratenanner.gif) ! |
Lo-Fi Version | Time is now: 13th November 2025 - 02:19 PM |
