| jeff |
Nov 18 2025, 11:55 AM
Member ![]() ![]() Group: Members Posts: 256 Joined: 17-January 04 From: thousand oaks,ca Member No.: 1,570 |
I have a long-term project I’ve been working on. GT flares,3.2-6 . 7” Fuchs front, 8” Fuchs rear
Anyone running Toyo 888r tires? I was thinking 225/50/15 in the front /235/50/15 rear Any advice we’ll appreciated . |
| VegasRacer |
Nov 18 2025, 08:48 PM
ELVIRA ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 8,907 Joined: 27-March 03 From: Between Scylla and Charybdis Member No.: 481 Region Association: None
I have a long-term project I’ve been working on. GT flares,3.2-6 . 7” Fuchs front, 8” Fuchs rear Anyone running Toyo 888r tires? I was thinking 225/50/15 in the front /235/50/15 rear Any advice we’ll appreciated . I am happily running Toyo Proxes R1R for dual duty. (225 - 50 - 16 on 8" Fuchs) Your biggest problem will be finding the sizes you mentioned in any tire. |
| campbellcj |
Nov 19 2025, 08:33 AM
I can't Re Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,665 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California
Hey Jeff, I hope all's well! I run 15's as well due to clearance and tires are pretty limited. Like a lot of the early car crowd I've got a set of the Michelin TB-series vintage tires (Coker) which look cool, period correct, but are modern construction tires. I find they are really bouncy compared to true modern tires, but could be a way to go.
Previously since my car was mainly track usage I put used Hoosiers on it if I went on the street but I had switched to non-streetable slicks for track. |
Lo-Fi Version | Time is now: 19th November 2025 - 09:35 AM |
