| trojanhorsepower |
Nov 26 2025, 03:28 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,002 Joined: 21-September 03 From: Marion, NC Member No.: 1,179 Region Association: None |
All,
I am looking to change the oil pump as a way to up my oil pressure. I understand that this may well not help, but having a new oil pump around is OK. With that in mind, what are my options? I will pull the motor but hope to not split the case. Is this even possible? Which pump? Thanks Peter |
Nov 26 2025, 08:25 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,553 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
Revisit my post #14 in your original thread.
You need to understand what is causing your issue before simply hoping for a better pump. Do you know what your current oil pump end clearance was? If you’re hell bent on buying a new Type 1 pump blindly, have the vendors measure the pump OD with a micrometer and get one that is the proper dimension. A couple thousands of an inch undersize is a huge deal and amounts to an internal leak that limits oil pressure - especially when hot and especially at idle. WRT to the question about splitting the case. You don’t have to split the case to swap an oil pump. |
| JamesM |
Nov 26 2025, 08:57 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,159 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
Yeah, what?
Are you looking for just a "new" pump or a larger pump? New type 4 pumps do not exist and none of the available type 1 pumps fit properly and (assuming you have a stock type 4 pump) will most likely make your pressure issues worse due to the excessive pump body to case clearances. A few vendors sell o-ringed pumps to try and remedy the clearance issues but 1. it doesn't fully as orings can only seal the sides of the pump and does nothing about the output leaking back to the input side AND 2. forget about trying to install an o-ringed pump on an already assembled engine. ALSO A larger pump may move more volume, and it will take more HP do to so, it may also not gain you any pressure and is likely to overwhelm your oil cooler bypass (which may already be occurring anyways) and roast your oil. Probably should be asked what sort of oil pressure are you currently looking at? What sort of oil are you currently running? and When was the last time you pulled your engine tin and cleaned out all the crap? If you insist on a band aid approach: Step 1. if you dont already have one, get one of @chrisfoley Oil pressure relief valves. Chances are if your oil pump is worn your bypass valve/spring are worse Step 2: If after that you still insist on replacing your pump talk to Jorge at European Moterwerks. He sleeves and machines a 27mm type 3 pump to work on a type 4. Its expensive for a VW oil pump but its the only one available that I am aware of with proper port placement, proper clearances, and no O-rings to tear installing on an assembled case. Someone in Europe had made a run of billet type 4 pumps a while back but haven't seen them in a while, and between the cost of the custom billet part and how the import tariffs have been hitting car parts you would have to really hate your money to bring one in now. If you’re hell bent on buying a new Type 1 pump blindly, have the vendors measure the pump OD with a micrometer and get one that is the proper dimension. A couple thousands of an inch undersize is a huge deal and amounts to an internal leak that limits oil pressure - especially when hot and especially at idle. I don't believe they exist, if you find a reliable source please let me know. You would still want to port match them as well. |
Nov 26 2025, 11:34 PM
Someone in Europe had made a run of billet type 4 pumps a while back but haven't seen them in a while, and between the cost of the custom billet part and how the import tariffs have been hitting car parts you would have to really hate your money to bring one in now. @JamesM I bought one of those T4 CNC billet pumps back when they were available. 30mm gears so limited use cases It does have the proper OD and port match Idler shaft was not pinned or peened as I prefer to do with any T4 pump. ![]() ![]() With respect to sizing of T1 pumps it’s a tolerance game - there are some out there that are only 0.001” undersize so it’s a sorting game to find the best parts. I don’t have a reliable source for “good” parts. Your info on the modified T3 pump is interesting. Have never seen that service listed on the website but good to know. |
| trojanhorsepower |
Nov 27 2025, 06:47 PM
@JamesM : Fresh build (20 years ago, but only installed recently). Turned crank, new cam and all bearings, p and c's also new etc. 20w50 oil. Tangerine bypass installed. Oil pressure when hot at low idle is low enough to turn on the oil light. The switch is A 3 psi or close to that unit.
I understand that a different pump may not fix my issue, but it seems worth a try. Is this incorrect? You guys make it sound like there are no good options for oil pumps? So new question if you are building a fresh 2056 for tooling around on the weekends what oil pump do you use? |
Nov 27 2025, 07:48 PM
I understand that a different pump may not fix my issue, but it seems worth a try. Is this incorrect? You guys make it sound like there are no good options for oil pumps? It is incorrect to try a new pump without measuring and knowing what you have. If you swap in a new pump with excessive gear end play clearance you’ll have accomplished nothing. If you swap in a new pump with a drastically undersize pump Outside Diameter - smaller than 2.756” you’ll have accomplished nothing Note: all info above ASSUMES you’re using a T1 pump - I’m not sure you’ve ever confirmed this? If you have a T4 pump we need to have some other conversations. |
Nov 27 2025, 07:55 PM
So new question if you are building a fresh 2056 for tooling around on the weekends what oil pump do you use? I’m going to start a (IMG:style_emoticons/default/stromberg.gif) storm but personally I use the OEM T4 pump with a pinned or peened idler shaft. The T1 pump quality control over the size of the pump Outside Diameter is a deal breaker . I know this contradicts what Raby used to promote but I believe he spends the time to either sort for best fitting T1 pump parts or is sleeving them himself. At one point I thought there was a thread where he was having pumps CNC machined up for himself to have proper OD +/- You can do & afford that level of detail at the prices he rightly charges. See post #13 http://www.914world.com/bbs2/index.php?showtopic=101423 |
| emerygt350 |
Nov 28 2025, 07:31 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,400 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
I have an old melling in mine. Works great but I know there is some hate out there on them.
| trojanhorsepower |
Nov 28 2025, 09:03 AM
OK thanks for the replies. I think I am getting there. Sounds like my best option for keeping the car on the road is to build the spare motor, measuring out the pump etc. Swap that in for the first motor then pull the pump measure everything find a pump and reinstall.
90% sure its a T1 pump now. @superhawk995 do you collect OEM T4 pumps and just go through them to find a good one or do you buy one from one of the main supplier and pin it yourself? Thanks, Peter |
Nov 28 2025, 09:34 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 602 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None
A couple options that might work for you?:
https://germansupply.com/type-4-oil-pump-billet.html https://www.cbperformance.com/product-p/1829.htm Personally, my next type iv motor will have a "blueprinted" o-ringed and modified type I pump from Gene Berg. And oil pressure will be carefully monitored both during initial start-up and use. That's with a gauge, not a light. (IMG:style_emoticons/default/smile.gif) Why? Because already have it and it's dimensions are within specifications. And, if it's not working right, it's replaceable. Edit: And the billet pump is listed at $412 (plus tariffs-taxes, shipping, etc.). But, also just noticed it's currently is out-of-stock. Might not ever be back in-stock? |
Nov 28 2025, 12:47 PM
@superhawk995 do you collect OEM T4 pumps and just go through them to find a good one or do you buy one from one of the main supplier and pin it yourself? Ya - I have a small collection of them that I’ve acquired from eBay, FS/WTB ads here, and from engines I’ve torn down. I have a mill so pinning them is easy for me. Unfortunately I am without a finished shop and my machine tools at the moment or I’d be happy to build a T4 pump for you. However, the process is straight forward for a T4 pump rehab and was well documented long ago on Samba Worth reading to at least understand the compromises being made with T1 pumps: https://www.thesamba.com/vw/forum/viewtopic.php?t=699156 I’m going to highlight an insightful quote from Raby that was in the other link I provided. “Components are constantly changing. What worked 35 years ago or just last month doesn't mean a damn thing. We see this more and more with the AFU Economy as companies are cutting corners to stay alive and sending out JUNK in some instances. Nothing ever stays the same- become set in your ways and you will get bitten in the ass. Constant awareness is key.” |
| JamesM |
Nov 28 2025, 01:01 PM
OK thanks for the replies. I think I am getting there. Sounds like my best option for keeping the car on the road is to build the spare motor, measuring out the pump etc. Swap that in for the first motor then pull the pump measure everything find a pump and reinstall. 90% sure its a T1 pump now. @superhawk995 do you collect OEM T4 pumps and just go through them to find a good one or do you buy one from one of the main supplier and pin it yourself? Thanks, Peter What pressure switch you have in there was going to be my next question as I have seen quite a few with to high a PSI set point that set off the light at idle. If you have an aftermarket T1 pump in there its possible (and I wouldn't be surprised) the case tolerances are (IMG:style_emoticons/default/stromberg.gif) Pretty easy to determine that, assuming it wasn't glued in as the sloppy pumps you can usually pull out by hand. A good fitting pump is a near interference fit where you will have to loosen the surrounding case half bolts and still most likely need to drive in. Check it out, if you can pull the pump with minimal effort call Jorge at European Motorwerks and get one of his sleeved type 3 pumps, that is the easiest route. I have seen acceptable results with the Melling pumps as well but prefer the modified type 3 for being aluminum bodied and having proper port alignment. |
Nov 28 2025, 01:03 PM
OK thanks for the replies. I think I am getting there. Sounds like my best option for keeping the car on the road is to build the spare motor, measuring out the pump etc. Swap that in for the first motor then pull the pump measure everything find a pump and reinstall. 90% sure its a T1 pump now. FWIW Since you are not 100% sure if what you have I’m going to assume you don’t know with certainty what your Pump end play clearance is. If it were me I’d pull the engine. Check the pump OD and and end clearance before rebuilding another whole engine. These two factors have an enormous influence influence over low engine speed oil pressure. This can be done over a weekend. |
Nov 28 2025, 01:13 PM
A good fitting pump is a near interference fit where you will have to loosen the surrounding case half bolts and still most likely need to drive in. The case oil pump bore ID is 70mm (2.756”) A OEM T4 pump is 2.757” This is a light interference fit. It’s not necessary to unbolt the case halves. Simply warm the case with a propane torch this will expand the pump bore. Slide pump right in. Easy peasy. |
Nov 28 2025, 01:22 PM
I have an old melling in mine. Works great but I know there is some hate out there on them. Melling has 30mm pump gears and is a good part of the reason you get away with runnning multi-grade oil 0W-40 if I recall? I ran one once back in the 80s on 10W-30 for a while. The problem is the cast iron pump and the aluminum case expand at vastly different rates. Any “leakage” is internal to the case just like the undersize T1 pumps. I used to get low oil pressure light flicker after extended high speed runs when pulling off the freeway. Would resolve itself as the engine cooled. Eventually went back to a OEM T4 pump. Problem solved. The biggest issue we are glossing over in these threads is that the oil pump is only 1 part of a system that includes up to 3 relief valves, bearing clearances, oil viscosity, temperatures the engine normally operates, and whether or not external coolers and plumbing have been added. There really is no one perfect solution. |
| trojanhorsepower |
Nov 28 2025, 02:49 PM
Man this is good stuff. Yes I understand that the pump is just one part of the system, I did tangerine bypass and it doubled my cold oil pressure (~ 35 AT cold idle to ~65 at cold idle). I think there is a bypass for the oil filter, but where is the 3rd bypass?
I like the idea of checking everything, but would like to have a pump ready to go in if I find something out of spec. So I will work on getting a T4 pump with OD of 2.757" then pull the motor and hope everything goes well. |
Nov 28 2025, 03:32 PM
Some cases have bypass down on the lifter galley. Can’t remember off the top of my head what cases have this. I know my early 73’ GA does.
Nov 28 2025, 03:35 PM
Lo-Fi Version | Time is now: 29th November 2025 - 09:28 AM |
