> Turn Signal Housing Stud
DennisV
post Nov 27 2025, 09:19 AM
Does anyone happen to know the specification (i.e. diameter and total length) for the stud on the front turn signal housing? One of ours is missing the stud and I need to replace it.
There is not separate listing for it in the parts catalog. I have flown back home now, so I don't have access to the car to tear apart the other side and measure it for reference.
Thank you.
Spoke
post Nov 27 2025, 10:34 PM
Jerry
It's a standard metric thread. 6mm dia x 1mm thread pitch I believe.
dtmehall
post Nov 27 2025, 10:39 PM
the factory only offered that as an assembly
the studs were not available separately
same on all the exterior lenses btw
doug_b_928
post Nov 28 2025, 01:19 AM
Region Association: Canada
If I recall correctly, I think it’s 25mm in length. You can make one by cutting the head off of an M6 bolt.
DennisV
post Jan 7 2026, 08:06 PM
QUOTE(Spoke @ Nov 27 2025, 08:34 PM) *
Closing the loop on this. Spoke was correct on diameter and pitch.
@doug_b_928 was very close regarding length. Best I can tell total length is 30mm.
Thanks all.
wonkipop
post Jan 8 2026, 04:09 AM
QUOTE(DennisV @ Jan 7 2026, 08:06 PM) *
Thanks all.
i have a complete factory bucket assembly.
give me a chance to dig it out and i will measure it.
- Lo-Fi Version Time is now: 9th January 2026 - 01:31 AM
