> Free floating axles, 914 application?
Mitox
post Nov 28 2025, 03:25 PM
This kit from JBugs looks like it would work on the 914. Maybe?
The sale Price looks good also.
https://www.jbugs.com/product/16-2236.html
VW 930 Axle Kit - 20 1/4" - with 28 Spline Axles
post Nov 28 2025, 05:28 PM
Yes it will work IF you have flanges and stub axles. Says they are BACKORDERED.
Mitox
post Nov 28 2025, 05:33 PM
QUOTE(914Sixer @ Nov 28 2025, 06:28 PM) *
Yes it will work. Says they are BACKORDERED.
I didn’t see the back order status - hopefully they would honor the pricing.
mb911
post Nov 28 2025, 07:18 PM
Mine are full floating and came from PMB
post Nov 28 2025, 08:10 PM
QUOTE(Mitox @ Nov 28 2025, 03:25 PM) *
914 CVs use two 10mm roll pins. Those are VW CVs with 6 bolts. I would drill two of the holes to 10mm ans install roll pins.
Not sure about the axle lenght as VW bug axles are shorter
post Nov 28 2025, 08:13 PM
QUOTE(Mitox @ Nov 28 2025, 05:33 PM) *
post Nov 28 2025, 08:43 PM
Corrected my yes statement. You need 911 hubs and stubs to make them work. Add about $1k for them.
post Nov 29 2025, 04:23 AM
QUOTE(914Sixer @ Nov 29 2025, 09:43 AM) *
Correct my yes statement. You need 911 hubs and stubs to make them work. Add about $1k for them.
If you have the 911 stubs and hubs along with the 108mm flanges on the transmission side (the same parts you will need for those $595 axles), these will work and are only $30 per axle:
https://www.rockauto.com/en/moreinfo.php?pk...288&jsn=475
Here's further discussion on the subject:
http://www.914world.com/bbs2/index.php?sho...=368822&hl=
This also means you'll need 5 bolt wheels, as the 28 spline hubs only come for the five lugs.
- Lo-Fi Version Time is now: 29th November 2025 - 09:28 AM
