| burton73 |
Nov 28 2025, 07:40 PM
Senior member, and old dude ![]() ![]() ![]() ![]() Group: Members Posts: 3,917 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California
So, you guys may not know, but my 6 the 30th one down the line in Dec 1969 had a few mods from back in the day when it was a test mule for a Socal Porsche high performance shop in the South Bay.
One cool future was a 911 oil level gauge and 911 sender in its factory 914-6 tank. Today I added a quart, and this was done in the way the factory manual says to do it. Now my car has and a GT oil cooler up front and it takes more oil. I warmed it up with a 1 mile drive and then checked it on level ground and it needed one quart to bring it between the min and the maximum line. As shown in the photos. Just so you know. Its kind of hard to see the oil level when the oil is very clean as it is a transparent gold against a goldish plated dip stick. Best Bob B ![]() ![]() |
| Dave_Darling |
Nov 28 2025, 11:51 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,295 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
Interesting, it looks like your speedo is on the left, so I'm guessing your combo gauge is on the right?
It was not unheard of back in the day for Six conversion cars to run a 911 combo gauge (oil temp/press) in place of the 914 one, and the 914 one added to the center console so you have the warning lights and fuel gauge there. Cool idea to have the smallest 911 gauge in the dash like that. --DD |
| rgalla9146 |
Nov 29 2025, 07:22 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,872 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None
Your oil level has to be checked at full operating temp. with the front cooler thermostat
open. I'm not sure one mile would be enough to be there especially with a front oil cooler. I'd check that the thermostat is open by listening for flow and touching both supply and return plumbing. If one is cold I'd drive it more. And hard. After that, as you said, level ground, at idle, mid-way between bottom and top marks on the dip stick. |
Nov 29 2025, 07:40 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,265 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
Adding to what Rory said. It takes at least 15-20 minutes of hard driving before you can really check the oil. It has to be over about 180 degrees for the thermostat to open (don’t quote me but it’s close). The engine and oil need to be HOT.
I get the engine warmed up enough that I can then start really revving it up some long hills. The difference in the oil level between warmed up a bit and hot is significant. 10-11 quarts of oil takes a while to go from 70 degrees to 190+. I don’t trust the oil gauge on a 911 one bit. Bob - it would be interesting to see where your current oil level is after a hard drive. |
| rgalla9146 |
Nov 29 2025, 08:22 AM
Adding to what Rory said. It takes at least 15-20 minutes of hard driving before you can really check the oil. It has to be over about 180 degrees for the thermostat to open (don’t quote me but it’s close). The engine and oil need to be HOT. I get the engine warmed up enough that I can then start really revving it up some long hills. The difference in the oil level between warmed up a bit and hot is significant. 10-11 quarts of oil takes a while to go from 70 degrees to 190+. I don’t trust the oil gauge on a 911 one bit. Bob - it would be interesting to see where your current oil level is after a hard drive. Bob your oil cooler and beautiful plumbing, along with many of the other performance modifications on your car were done in the earliest days of 914 6 enthusiasm. As Mark and I know, and certainly you too, Peter Dawe did that work way back then. You've done a great job restoring and preserving a very worthy car. |
Nov 29 2025, 09:02 AM
Peter still builds race winning engines and cars. He’s one of the all time greats.
| Cairo94507 |
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,503 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California
On my Six, with the extra large (PMS) oil cooler and GT hard lines to get the oil there and back, I have about 12 quarts in my system. I need to drive a good 15 minutes to get the oil hot enough for the thermostat to open and get oil circulating. I can usually, (if paying attention) see the oil temp climbing and then the thermostat opens and I can see temperature drop and then stabilize. I usually check my oil whenever I return from a long drive and it is nice and hot. I pull into the garage, open the engine lid and let it idle for a good 2 minutes and then check the level.
Bob is 100% correct with how difficult it is to see the oil on the dip stick. Mine is yellow cad plated and my oil stays clean too. I lay a paper towel downed lay the dip stick on it and that is the only way I can see the oil level on the dip stick. Works like a charm. (IMG:style_emoticons/default/beerchug.gif) |
| FlacaProductions |
Nov 29 2025, 09:26 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,099 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California
looking forward to seeing you again later today, Bob - and getting to see your 6!
I'm new to my 67 911 and still getting used to checking the oil - and have the same issues of being able to actually see the oil on the dipstick. That's a good paper towel tip, Cairo - thanks. |
Lo-Fi Version | Time is now: 29th November 2025 - 09:29 AM |
