> WTB - 914 Engine cooling fan and lower shroud flaps
TRP
post Dec 1 2025, 04:36 PM
Hello,
I'm looking to buy a replacement cooling fan for the 2056 I'm building. The fan that came with the donor core is missing three fins.
Also looking for the two lower shroud flaps for the 914 cooling shroud. Again, the donor motor is missing the little lower tin flaps.
Thank you,
Ted Pierson
post Dec 1 2025, 06:30 PM
914Rubber has the cooling flaps
GregAmy
post Dec 1 2025, 06:44 PM
Ted, I have a stock 914 cooling fan and housing, and it may have flappers*; I replaced the one in my racer (no heat needed) with a bus one (they use gas heaters). The housing is powdercoated gray, though. Photo before I replaced it.
PM me and we can coordinate.
*As noted above, 914 Rubber has new replacements
1 Members: TRP
- Lo-Fi Version Time is now: 2nd December 2025 - 09:04 AM
