> New To The Forum, Intro and Pictures of my project
Pete_Aron
post Dec 7 2025, 02:45 PM
Hi to everyone. I just picked up a 1970 914/4. It needs a lot of work. It came with the engine and transmission out of the car. The engine was under a tree covered with some plastic. It turns but after about a quarter turn something is stopping it inside.
The engine serial starts with EA, which I think makes it a 1972 or 1973 1.7. Definitely not original to the car. No starter, no alternator, no exhaust, no FI. The transmission was in the frunk.
I'll be tearing it down in a couple of weeks. I'd like to make some mild performance improvements. Looking for reliability rather then horsepower. A budget build if that's even possible with one of these.
Feel free to chime in with crank, cam, valve possibilities. Looking forward to learning from this forum and sharing my experience here. Thanks, Chris
brant
post Dec 7 2025, 02:58 PM
Nice first post
The blocks are the same. So at least you have something to build if you get the machine work done. Easy to build a bigger motor with crank rods and pistons for mild.
post Dec 7 2025, 03:04 PM
Looks great, have you explored the rockers, hell hole, any potential rust areas?
Engine and trans are the easy issues
SO.O.C914er
post Dec 7 2025, 03:59 PM
(IMG:style_emoticons/default/welcome.png) Welcome to our mid-engine madness!
Pete_Aron
post Dec 7 2025, 04:13 PM
QUOTE(930cabman @ Dec 7 2025, 04:04 PM) *
I have not had a chance to look closely at the rockers or hell hole. A quick look at the hell hole shows someone did a recent rebuild of the area and didn't do a super great job. It will need attention.
The PO said the jack points were "soft" which means they're probably gone. Gonna strip out the interior and try to get it into the air and get a good look in a couple of weeks.
post Dec 7 2025, 05:48 PM
post Dec 7 2025, 08:05 PM
(IMG:style_emoticons/default/welcome.png) and welcome to the madness.
You are at the right place for any and I mean ANY of your 914 related questions. There are extremely knowledgeable people here always willing to give great help. (IMG:style_emoticons/default/smilie_pokal.gif)
Your shell seems clean, but as mentioned, you should take a close look before diving into the engine build. Of course, engine is the fun part but unfortunately, the shells can require a lot of work. Plenty of built threads that you can refer to if you get deep in the sheet metal.
We are suckers for pictures (IMG:style_emoticons/default/biggrin.gif) feel free to add some more… Phone pictures are too large, you need to resize them using something like Paint to about 300k.
Good luck with your project! (IMG:style_emoticons/default/driving.gif)
bkrantz
post Dec 7 2025, 08:35 PM
Welcome and good luck. If the engine turns reasonably easy, especially with spark plugs removed, it may be a dropped valve. Don't force it to keep turning.
Artfrombama
post Dec 7 2025, 09:47 PM
Artfrombama
I’ve seen these engines stuck with just some carbon at TDC, since the motor is out it’s easy to pull the heads and check it out.
post Dec 8 2025, 08:30 AM
(IMG:style_emoticons/default/welcome.png) Welcome Chris; that looks like a nice car to start with. You might look into a 2056 build if you end up rebuilding the complete motor. (IMG:style_emoticons/default/beerchug.gif)
post Dec 8 2025, 09:13 AM
Pete_Aron
post Dec 8 2025, 03:09 PM
QUOTE(Montreal914 @ Dec 7 2025, 09:05 PM) *
Thanks Good to know about pictures.
krazykonrad
post Dec 8 2025, 03:28 PM
(IMG:style_emoticons/default/welcome.png) Welcome aboard! Address the body issues first, then the engine.
PanelBilly
post Dec 9 2025, 08:48 AM
(IMG:style_emoticons/default/welcome.png) I agree about working on the body first. Poke around with a screwdriver and see what you find. You picked a good car for rebuilding. Thanks to our suppliers, you can get nearly every part to fix any problem. Just comes down to spending $$$ vs value of car.
post Dec 9 2025, 01:47 PM
You have found the right place to get answers to most of of your 914 questions.
Take a look at the sandbox. I did not look there for my 1st 13 years on here. Lots of fun there.
Enjoy! Best Bob B
worn
post Dec 9 2025, 07:08 PM
QUOTE(PanelBilly @ Dec 9 2025, 06:48 AM) *
(IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/welcome.png) I like the description including the things that didn’t come with the car. Replacing them will give you satisfaction and assurance that you have at least some confidence that those areas are taken care of. Unless of course they aren’t. The folks here represent what the internet ought to be.
mark04usa
post Dec 9 2025, 11:28 PM
'70 1.7 Tangerine
(IMG:style_emoticons/default/welcome.png) Nice early car. Does it have a Dec 69 production date?
Tonyooc
post Dec 9 2025, 11:32 PM
(IMG:style_emoticons/default/welcome.png) Have fun with your new project.
rick 918-S
post Dec 10 2025, 07:26 AM
Hey nice rack! -Celette
So far it looks like a nice car to start with (IMG:style_emoticons/default/welcome.png) Get Busy! (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/welder.gif)
campbellcj
post Dec 11 2025, 09:24 PM
I can't Re Member
(IMG:style_emoticons/default/welcome.png) You definitely are in the right place for any help, parts and moral support! I hope your journey with 914 addiction goes well and look forward to future updates.
