| 74ravenna |
Dec 8 2025, 05:34 AM
Member ![]() ![]() Group: Members Posts: 479 Joined: 19-October 14 From: nh Member No.: 18,032 Region Association: North East States
I recently bought new rotors for my 74 but they are too small in diameter so they won't slide all the way on. They were purchased based on model year so I'm confident that I was sent the proper size. The seller suggested that the spindles aren't original so I've tried to find the diameter of a 74 spindle but can't find it anywhere. I was sure my Haynes would have it listed, but no luck there. Google had nothing as well. If anyone here has that info I would appreciate it. Thanks.
| bdstone914 |
Dec 8 2025, 08:12 AM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,264 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I recently bought new rotors for my 74 but they are too small in diameter so they won't slide all the way on. They were purchased based on model year so I'm confident that I was sent the proper size. The seller suggested that the spindles aren't original so I've tried to find the diameter of a 74 spindle but can't find it anywhere. I was sure my Haynes would have it listed, but no luck there. Google had nothing as well. If anyone here has that info I would appreciate it. Thanks. All 914 struts have the same spindles size. The early vs late struts have a different offset for the caliper Mounting. 911 struts have a larger spindle. What is the brand and part number marked on the package and what part number did you order. .abd chance you have 5 lug 811 struts |
| 74ravenna |
Dec 8 2025, 09:03 AM
I will recheck the part numbers on what I was sent versus what I ordered in a bit. The seller did confirm what I ordered was/is correct for my MY car and what they shipped was correct and then suggested the possibility of different spindles. I will double check though. Thanks for your help.
| ejm |
Dec 8 2025, 10:34 AM
I can see the light at the end of the tunnel ![]() ![]() ![]() ![]() Group: Members Posts: 2,715 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
What about the wheel bearings? New rotors generally don't come with bearings. Did you get new ones or swap them from the old rotors?
| 74ravenna |
Dec 8 2025, 04:23 PM
I got new bearings to go with the new rotors.The bearings are BR8 manufactured by SKF. 4 lug.
| 74ravenna |
Dec 8 2025, 04:27 PM
I just noticed that my original post says I bought new rotors that don't fit but that is incorrect. I bought new bearings that don't fit. Sorry.
| rjames |
Dec 8 2025, 05:24 PM
I'm made of metal ![]() ![]() ![]() ![]() Group: Members Posts: 4,438 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest
If the bearings you bought are correct for your spindles, it's not uncommon for them not to want to slide on all the way if you don't have the bearing lined up perfectly straight when trying to mount the rotor assembly.
If in doubt, use calipers to measure the diameter of the spindle an the ID of the bearing. |
| 74ravenna |
Dec 9 2025, 08:00 AM
If the bearings you bought are correct for your spindles, it's not uncommon for them not to want to slide on all the way if you don't have the bearing lined up perfectly straight when trying to mount the rotor assembly. If in doubt, use calipers to measure the diameter of the spindle an the ID of the bearing. I will go this route, it only makes sense. I don't have calipers and that's why I haven't yet but I'll buy a set. The bearings stop sliding on with so much distance left to go, plus the fact that they both stop sliding on at the same spot on each side made me automatically think that they aren't correct for my spindles. This will be interesting. Thank you. |
Dec 9 2025, 08:03 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,508 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
Show us a picture of your strut.
Lo-Fi Version | Time is now: 3rd March 2026 - 03:28 AM |
