| Flyinlow |
Dec 14 2025, 05:32 PM
Flyinlow ![]() ![]() Group: Members Posts: 103 Joined: 17-October 20 From: British Columbia, Canada Member No.: 24,774 Region Association: Canada
Would like some help… Three sets twin white wires 74 2.0 D-Jet harness I believe are the ground wires.Does anyone have a picture of how this works TIA Dennis
| JeffBowlsby |
Dec 14 2025, 06:20 PM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,139 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
They connect to a trispade terminal which mounts to the upper engine case, rearmost case bolt.
| windforfun |
Dec 14 2025, 06:50 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,082 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None
Clean all your connectors with a wire brush & deoxit. Great grounding is fundamental in any electrical system.
| Flyinlow |
Dec 15 2025, 10:47 AM
| Ron914 |
Dec 15 2025, 11:36 AM
Member ![]() ![]() Group: Members Posts: 471 Joined: 19-April 22 From: Huntington Beach,Ca Member No.: 26,487 Region Association: Southern California
| Highland |
Dec 15 2025, 06:12 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 558 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California |
Curious why there are multiple ground wires on the FI harness. Why not just 1 wire or ground the ECU case to the mount (chassis)?
| Flyinlow |
Dec 15 2025, 06:30 PM
Yes I see where you’re at there much easier than the original spot on 74 car…I can make something that will work there. btw it would seem I should have connected those ground wires before engine install… lesson learned!! |
| JeffBowlsby |
Dec 15 2025, 07:18 PM
Curious why there are multiple ground wires on the FI harness. Why not just 1 wire or ground the ECU case to the mount (chassis)? 6 circuits total. 1 ground for each injector, 1 for the ECU, 1 for the TPS. They could be functionally combined into a single ground point. Probably configured this was for easy harness construction. |
Lo-Fi Version | Time is now: 15th December 2025 - 07:38 PM |
