> warm up regulator for MFI, conversion to manual
Speedo
post Dec 15 2025, 12:58 PM
What are my options? Does anyone offer a conversion kit other than Supertec?
I'm going to run a 2.4 MFI engine for a while. I don't want to weld up an MFI hot air bung in my factory heat exchangers.
rudedude
post Dec 15 2025, 01:26 PM
There are a number of fuel injection components that also need to be fitted. Might be easier to put the webers you have for your project.
Speedo
post Dec 15 2025, 04:24 PM
QUOTE(rudedude @ Dec 15 2025, 12:26 PM) *
Fuel pump swap, low to high pressure...and hi-press fuel lines (stainless already in tunnel)
Fuel filter console
Warm up regulator/enrichment solution
What else?
Swap 911 engine tin for 914-6 MFI tin
Choice of aircleaners stock vs modified
Configure horizontal trombone cooler with oil lines
Maybe Ferg and Emory will weigh in...its their fault. : )
Speedo
post Dec 15 2025, 05:37 PM
I may have just figured it out. My tin has the MFI tube, and my HEs also have the warm up tube. No mods needed, other than some hose. : )
IronHillRestorations
post Dec 16 2025, 07:36 AM
I. I. R. C.
You also need the RPM transducer to activate the idle position solenoid on the MFI pump
1 Members: Dave97
- Lo-Fi Version Time is now: 16th December 2025 - 09:30 AM
