> Leave oil pressure relief valve?, Rebuilding
oakdalecurtis
post Dec 19 2025, 11:25 AM
Oakdalecurtis
I am having my 76 2.0 motor completely rebuilt, everything new except the block. Should I tell the shop to reinstall the Tangerine Racing oil pressure relief valve that was in the old motor?
rfinegan
post Dec 19 2025, 02:45 PM
Most blocks can benefit from the tangerine valve, think that is why he made it. It fixes the worn block and prevents sticking and leaking
Dominic
post Dec 20 2025, 05:34 PM
Dominic
QUOTE(oakdalecurtis @ Dec 19 2025, 10:25 AM) *
What size oil pump are you running? Do you have any external oil cooling lines?
You may not need the increased pressure
Dominic
post Dec 20 2025, 05:35 PM
Dominic
post Dec 20 2025, 05:45 PM
QUOTE(oakdalecurtis @ Dec 19 2025, 12:25 PM) *
How will she run without a relief valve? I have always used the stock setup, never had an issue
- Lo-Fi Version Time is now: 20th December 2025 - 06:52 PM
