| Cfletch |
Dec 26 2025, 02:07 PM
Member ![]() ![]() Group: Members Posts: 216 Joined: 30-January 14 From: Santa Barbara Member No.: 16,941 Region Association: Southern California |
Hey there, some of you guys may remember my issues I was having with my weber carbs that ultimately ended up being a distributor problem. I have sorted all of that out and the car is ready to go to a shop to get an alignment, shifter adjustment, and carb tune. I called them up and they are about 3 months out, so I might get pretty bored and want to attempt more tuning on my end.
Engine is a 2.7L stock CIS engine with Weber 40IDA3C carbs. 123 distributor and an MSD box. Current problem: Car when stone cold after a week of not running is slightly hard to start, but once its running it idles just fine and does not need any throttle aid to keep the engine alive. Once it is warm enough, I give it some gas to get it to rev up and it really hates going past say 2k RPM. I can baby it to get it past that limit and then it revs up just fine from past 2k or so all the way up to ~6k. I am doing some digging and trying to see what is causing this stumble from idle. Based on my loose reading on other forums, it seems as though the car is on the lead end and could use larger idle jets. Anyone been through this before? Carb Jet specs are as follows- suggested from Paul Abbott. Mains: 135 Idle:55 Air Correction: 180 Emulsion Tubes: F26 Venturis: 32 I have even gone as fast as asking AI- which is not something I rely on but wanted maybe some validation and it agreed that 55 idles were too small, also suggested F26 tubes were too lean and I should do something like F16 instead. Any suggestions are welcome as I have about 3 months to mess around with this till it goes to the shop. Thank you! |
| Tdskip |
Dec 26 2025, 02:35 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,748 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None
Get lots of other opinions, but sounds like the transition from idle to the secondary is not having
| slivel |
Dec 26 2025, 03:07 PM
Old car....... older driver ![]() ![]() ![]() Group: Members Posts: 539 Joined: 10-July 04 From: San Diego Member No.: 2,332 Region Association: Southern California |
If you have verified that the ignition system/timing is correct, then I recommend that you check your carbs in the following order:
1. Pull all jets and ensure they are not clogged 2. Check accelerator pump circuits are delivering suitable stream of fuel 3. Check float bowl fuel levels |
| Steve |
Dec 26 2025, 03:15 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,993 Joined: 14-June 03 From: Laguna Niguel, CA Member No.: 822 Region Association: Southern California
I had an intermittent issue with my 2.7 off the line or getting to the mid range. Going from 55 to 60 idling jets fixed the problem. It was also a stock CIS engine.
Dec 26 2025, 03:16 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,398 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
Spark timing?
Popping through intakes when revving? Fuel pressure? |
| slivel |
Dec 26 2025, 03:17 PM
For comparison, my 3.4 has this:
Weber 46's, chokes: 40, main jets: 185, idle jets: 60, air correctors: 155, emulsion tubes: F7. Paul Abbot also did my carbs so if those were the recommended jets, ac's, and et's, I would guess that you are in the ballpark. If you have the jets removed also blow compressed air through the jet passages. I would highly suspect the accelerator pump circuits are not functioning properly and delivering the volume of fuel necessary to make the transition from idle circuit to main. |
| Cfletch |
| Cfletch |
Dec 26 2025, 07:22 PM
Spark timing? Popping through intakes when revving? Fuel pressure? Pressures at 3.5 lbs, some popping through intakes which to me says lean more than timing. 123 distributor is installed, was set to Z1 on crank cyl #1 tdc and the curve was given to me from Perry. I don't suspect any weird ignition issues. |
| gereed75 |
Dec 26 2025, 07:48 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,411 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States
The idle jets dominate fuel delivery up into the 4000 rpm range. I like the suggestion of going larger. It is unlikely that you are running so rich through the transition range that the engine is “flooding”, so larger seems prudent. If that is wrong you’ll know quickly as it will get worse
Could be the accel pumps and jets. look down into the throats ( engine not running) and look to see fuel squirting in when you pump the throttles. It probably either is squirting or isn’t. It’s a pretty coarse fuel add. Working or not working. My carbed 2.4S runs pretty good and idle is pretty solid - but it still spits/chuffs occasionally pretty much all the time when running at partial throttle. I always assume it comes with the territory |
| gereed75 |
Fat thumb dbl post
| Cfletch |
Dec 26 2025, 08:23 PM
The idle jets dominate fuel delivery up into the 4000 rpm range. I like the suggestion of going larger. It is unlikely that you are running so rich through the transition range that the engine is “flooding”, so larger seems prudent. If that is wrong you’ll know quickly as it will get worse Could be the accel pumps and jets. look down into the throats ( engine not running) and look to see fuel squirting in when you pump the throttles. It probably either is squirting or isn’t. It’s a pretty coarse fuel add. Working or not working. My carbed 2.4S runs pretty good and idle is pretty solid - but it still spits/chuffs occasionally pretty much all the time when running at partial throttle. I always assume it comes with the territory I can quickly tell you all then that the accel pumps are working. I never checked the delivery amount and can if it comes down to that, but jabbing the throttle squirts an amount into each throat per bank so that checks. Would a temp test be to back out the idle mixture screws some to richen up the mixture and see if that helps my problem, or would that not really give as much adjustment as going from say 55 idle jet to 60 idle jet? |
| brant |
Dec 27 2025, 10:51 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,116 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
I can quickly tell you all then that the accel pumps are working. I never checked the delivery amount and can if it comes down to that, but jabbing the throttle squirts an amount into each throat per bank so that checks. it does come down to that makes a very significant difference you have to check the volume of the accel pumps on each throat then you equalize each throat and bring them equally up to 7 units weber sells a tool for this that is a small glass vial with graduated measuring marks the diaphragms harden with age and reduce the volume over time need to be replaced and rebalanced every 3-4 years replacement involves pulling the linkage and rebalancing everything per set up instructions brant |
| rgalla9146 |
Dec 27 2025, 12:37 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,901 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None
'bring them equally up to 7 units' I've never heard this expression. Please explain. |
| brant |
Dec 27 2025, 01:28 PM
'bring them equally up to 7 units' I've never heard this expression. Please explain. the measuring vial is numbered in units the accelerator pump diaphragm is adjustable for output volume as the rubber diaphragm hardens it pushes less volume (flexes less) adjust them to be equal 6-7 units is the goal for a 911 carb just what it sounds like |
| brant |
Dec 27 2025, 01:35 PM
Dec 27 2025, 03:06 PM
The idle jets dominate fuel delivery up into the 4000 rpm range. I like the suggestion of going larger. It is unlikely that you are running so rich through the transition range that the engine is “flooding”, so larger seems prudent. If that is wrong you’ll know quickly as it will get worse Could be the accel pumps and jets. look down into the throats ( engine not running) and look to see fuel squirting in when you pump the throttles. It probably either is squirting or isn’t. It’s a pretty coarse fuel add. Working or not working. My carbed 2.4S runs pretty good and idle is pretty solid - but it still spits/chuffs occasionally pretty much all the time when running at partial throttle. I always assume it comes with the territory I can quickly tell you all then that the accel pumps are working. I never checked the delivery amount and can if it comes down to that, but jabbing the throttle squirts an amount into each throat per bank so that checks. Would a temp test be to back out the idle mixture screws some to richen up the mixture and see if that helps my problem, or would that not really give as much adjustment as going from say 55 idle jet to 60 idle jet? I am having similar issues with a fresh 2.7 CIS engine. I have a set of 60 idle jets and the measuring vial, just waiting to get her out of the paint shop. My gut is telling me the larger idle jets will do the trick |
| Cfletch |
Dec 27 2025, 03:22 PM
The idle jets dominate fuel delivery up into the 4000 rpm range. I like the suggestion of going larger. It is unlikely that you are running so rich through the transition range that the engine is “flooding”, so larger seems prudent. If that is wrong you’ll know quickly as it will get worse Could be the accel pumps and jets. look down into the throats ( engine not running) and look to see fuel squirting in when you pump the throttles. It probably either is squirting or isn’t. It’s a pretty coarse fuel add. Working or not working. My carbed 2.4S runs pretty good and idle is pretty solid - but it still spits/chuffs occasionally pretty much all the time when running at partial throttle. I always assume it comes with the territory I can quickly tell you all then that the accel pumps are working. I never checked the delivery amount and can if it comes down to that, but jabbing the throttle squirts an amount into each throat per bank so that checks. Would a temp test be to back out the idle mixture screws some to richen up the mixture and see if that helps my problem, or would that not really give as much adjustment as going from say 55 idle jet to 60 idle jet? I am having similar issues with a fresh 2.7 CIS engine. I have a set of 60 idle jets and the measuring vial, just waiting to get her out of the paint shop. My gut is telling me the larger idle jets will do the trick Tomorrow I will give it the inital drive around the block- never actually taken it on the road just yet but got insurance and reg done yesterday. Ill open up the idle screws and see how it goes. I think ill just struggle to get it past 2k on load but would maybe be okay after? Need to adjust the shifter linkage though because I cant find couple of gears. too excited to not try first gear around the block |
Lo-Fi Version | Time is now: 27th December 2025 - 07:15 PM |
