| JeffBowlsby |
Dec 31 2025, 04:42 PM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,151 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
Replacing an original factory clutch dated 7/73, as it had started shuddering at launch and making weird noises. A "while I was in there" job. ~50Kmi car. This transaxle had never been previously removed from the car.
See the original disk compared to the new replacement disk. The orig clutch disk has some kind of rubber 'spring/cushion chunks ' inside, mostly deteriorated and most of the rubber chunks are missing now. A piece of a remaining chunk can be seen in the round hole viewport at the clutch disk center. Original flywheel had been factory balanced and the bolts were not clearanced. No visible wear on flywheel bolt heads. Clutch disk is made of two thinner friction disks separated by a center metal plate carrier plate with flat springs presumably to somewhat cushion the shift change process. I noticed that the friction disk on the pressure plate side had more wear (was thinner) than the friction disk on the flywheel side. Attached thumbnail(s) |
JeffBowlsby Replacing original factory clutch Dec 31 2025, 04:42 PM
914Sixer Original clutch was made by LUK. Still in busines... Dec 31 2025, 05:13 PM
Superhawk996 Sheesh - haven’t seen an original clutch myself ... Dec 31 2025, 05:27 PM
sixnotfour 68 912..just replaced same clutch dated /74 Dec 31 2025, 06:17 PM
Ninja Does anyone know when Porsche moved to the damper ... Dec 31 2025, 06:46 PM
wonkipop had one of those in mine.
pulled it out in 2020 wh... Dec 31 2025, 08:08 PM
rgalla9146 If the clutch disc can not 'float' on the ... Dec 31 2025, 10:16 PM
930cabman Very cool this "obsolete style" disc las... Jan 1 2026, 07:29 AM![]() ![]() |
Lo-Fi Version | Time is now: 1st January 2026 - 08:27 AM |
