3 Pages V  1 2 3 >
> HEDALIGHT Disperate faulty, Unexpected fault
searunner
post Jan 4 2026, 12:23 PM
yesterday coming into my garage, I hear one ritming song- under the cover of my 914 2.0 1974, one strange movement, the LEFT Headlamp go UP and DOWN
The RIGHT Headlamp stays in the closed position.
Normally, I detach the battery of the car when in the garage, but I forgot this time.
The car was without a KEY IN - the Light switch was off -
The last trip with the car ALL was regular, and the headlamp was in working condition.
I can STOP the movement, detaching the battery- but this NO was the solution,
Then I searched for a better solution.
Extract completely the Light switch -(with the BATTERY connected and KEY ON) I have the two headlamps is up and in stable condition - also when I START the engine and move the car, and make a long trip
But if I return the light switch to the POSITION light, the LEFT Headlight return to UP_DOWN movement.
Is clear that I have one short- Or one Relay issue - BUT 914 was full of relays
Can someone help me, to return to a normal 914 ??
I am not a native English so overlook my errors
TheCabinetmaker
post Jan 4 2026, 04:17 PM
I drive my car everyday
I've had this exact problem. Mine happened in a hard rainstorm. Once it dried it was fine, but, it happened again a few years later when it was not raining. It was a corroded pin on the round relay at the headlight from the past rainstorm
post Jan 4 2026, 07:26 PM
You mean the relays in the frunk? What a crazy issue.
ejm
post Jan 5 2026, 10:23 AM
I can see the light at the end of the tunnel
Inside the headlight motors are switches that stop them in the correct up or down position.
Swap the relays that are below the motors. If the trouble moves to the other side it is a relay problem. The switches in the motors can be cleaned and adjusted.
post Jan 5 2026, 11:36 AM
You can find these relays under the protective plastic cover in the frunk. They just pull out easily.
Maltese Falcon
post Jan 5 2026, 06:03 PM
QUOTE(ejm @ Jan 5 2026, 08:23 AM) *
Good point ! I have cleaned these (internal discs and 'Stylus style) switches inside the headlight motor housings. These can also easily short out/ or conduct erratically >> by deposits of lube grease that drops out of the small gears in there on to the disc's. Weird... but not 'Pasta my trouble shooting capabilities ¡
(IMG:style_emoticons/default/marty914.jpg)
searunner
post Jan 7 2026, 01:02 PM
[/quote]
I thank all for the suggestions.
I have one RED -Relay normally dedicated to the electrical pump- substituted for the oldest black BUT UP & DOWN continue-
I have in my second garage, 3 new BLACK relays,
but the weather is very bad, stormy and snowy. I try a substitution as soon as possible- I will inform you if the problem is solved
post Jan 7 2026, 02:00 PM
[quote name='searunner' date='Jan 7 2026, 02:02 PM' post='3239870']
[/quote]
[/quote]
These are the relays in the frunk next to the headlight motors? Just swap them side to side.
post Jan 7 2026, 02:07 PM
(IMG:style_emoticons/default/idea.gif) Gremlins (IMG:style_emoticons/default/idea.gif)
searunner
post Jan 9 2026, 12:43 PM
QUOTE(930cabman @ Jan 7 2026, 02:07 PM) *
YES is a gremlin - I have tried one new relay, but the result was negative- the gremlin is [b]NOT THE RELAY - Probably the oldest is good, I have tested it and have the same results as the newer-
I must done two
1) On my car, I have modified the fog lamp to DAY LIGHT with Attached Imagetwo LED connected directly to the POSITION LIGHT -
My FOG SW is completely detached from the diagram.
2) The DRIVER Headlight is OK, follow all commands
The PASSENGER Headlight have this strange gremlins
This DIAGRAM can elucidate better: Passenger HEAD L. DRIVER HEAD L.
CAR BATTERY EXCLUDED DOWN DOWN
CAR BATTERY CONNECTED UP & DOWN immediately DOWN
KEY OFF UP&DOWN continue DOWN
KEY ON UP&DOWN continue DOWN
LIGHT SW ON -POSITION Light UP&DOWN continue DOWN
LIGHT SW ON -HEAD Light UP Light ON UP OK
LEVER control - ON Low Light UP Light ON UP OK
LEVER control - ON Head Light UP Light ON UP OK
[/b]So My 914 can be drive on the road only with the Head light on UP positionAttached Image
searunner
post Jan 9 2026, 12:48 PM
The car photo was before the gremlins appeared
The LED was adhesive - applied on the glass of the FOG lamps
post Jan 9 2026, 01:35 PM
I’m afraid I’m really struggling with the language barrier so I don’t think I’m fully understanding your problem.
But let me offer three things:
1) read this link to understand a simplified diagram of the wiring set up for the headlamp motors.
www.914world.com/bbs2/index.php?showtopic=20605&st=0
2) be aware that there are two diodes that are soldered to the headlamp motor terminals to prevent undesired current paths.
When these diodes go bad (either open or shorting internally) weird things happen to the motor operation.
3) the wiring diagram for the headlamp motors is well documented in both the Haynes and Factory service manual
As a final suggestion I’d start by reviewing any modifications you may have made when you modified the fog lamps.
PS: I lived in Martina Franca for about 2 years. Unfortunately my Italian was never good. Italy is such a beautiful country. I hope to visit again before I pass from this life.
searunner
post Jan 10 2026, 05:32 AM
Many Thanks for the precious suggestion -
I have no idea of the presence of the two diodes, probably the gremlin of my passenger's headlight can be the cause. I try to control the diode condition with a tester
My DIAGRAM was written in a good and precise way, put in columns -
BUT when it was published, everything had changed, to this chaos
in the september 2025 I was in PUGLIA with my MG TC 1946 for a raid around MONOPOLI and BARI and MATERA of 8 day too limited to visit Martina Franca
I live near TRIESTE at extreme NORTH EAST of ITALY near the border of SLOVENJA
searunner
post Jan 11 2026, 04:16 AM
One more understandable 914 GREMLINS FRAMEWORKS Attached Image
post Jan 11 2026, 09:57 AM
https://www.pelicanparts.com/techarticles/9...u64TwIEL1iWM1uN
searunner
post Jan 12 2026, 06:07 AM
Thanks - actually, I dismantle the Passenger Headlamp motor (it's impossible to test the DIODES with it in its operative position)
searunner
post Jan 15 2026, 12:35 PM
The DIODE APPEARS good. (I test the PASSENGER SIDE) My opinion is that is VERY strange that gremlins appear when the
BATTERY is OFF
-the LIGHT SWITCH is OFF
The ACCENSION KEY is OFF
and the HEADLIGHT (passenger side) is UP & DAWN continue
The CAR in this condition have to be ALL under KEY
And Passenger HEADLIGHT OFF. Now I must investigate the Key Relay
searunner
post Jan 15 2026, 12:47 PM
I forgot that in this condition, the TRIPLE Connector(Passenger side HeadLight)
The RED wire sends electrical power. Detaching it all STOPS
post Jan 15 2026, 07:59 PM
QUOTE(searunner @ Jan 15 2026, 02:35 PM) *
BATTERY is OFF
Can you elaborate what you mean by gremlins appear when the battery is off? I believe you said previously that if the battery is disconnected that this stops the up/down moment (as it should).
Is your car euro spec or an imported US car?
post Jan 15 2026, 08:03 PM
QUOTE(searunner @ Jan 15 2026, 02:47 PM) *
Disconnecting the red wire would be expected to stop the behavior since that is the power feed to the relay, and then to the motor.
If you simply remove the passenger side relay - does this stop the passenger side up/down behavior?
If you remove the driver side relay - does that stop the passenger side up/down behavior?
Note: only remove one relay at a time
3 Pages V  1 2 3 >
- Lo-Fi Version Time is now: 19th February 2026 - 09:45 PM
