> Voltmeter reading? Accuracy?
SKL1
post Jan 5 2026, 09:52 PM
Trying to figure out how accurate the OEM voltmeter is in my '73 2.0. To make a long story shorter the engine in the car is a much modified 1.9 from my '71, with approx 120K miles on the alternator.
Voltmeter reads around 11V and drops to 10 if I turn on the headlights. Immediately goes back to 11 or just over that with the lights turned off.
Replaced the voltage regulator this AM and did a test drive with no change. Gauge never gets close or above 12V. Makes me afraid to drive it at night with the lights on and go very far.
Do I need to go through the hassle of rebuilding the alternator or trying the alternator from the original 2.0 engine that has about 70K miles on it?
Better way to get a more accurate reading of actual voltage?? I hate electrical issues!!!!
TIA.
mjrrti
post Jan 5 2026, 11:16 PM
High Desert Member
QUOTE(SKL1 @ Jan 5 2026, 07:52 PM) *
TIA.
I just bought a cig lighter usb charger on Amazon for about 9 bucks. It has a digital volt meter built into it. I bought it for usb use but it reads the same as the aftermarket sun pro voltmeter I have in my car. Should give you a good idea of where your factory gauge stands. I don’t know how to attach a link but here is a pic.
mjrrti
post Jan 5 2026, 11:22 PM
High Desert Member
The brand didn’t show in my pic but it is zeehoo. There are a bunch to choose from anyway. (IMG:style_emoticons/default/smile.gif)
post Jan 6 2026, 05:58 AM
I have found voltmeter readings somewhat erratic, but mine does read 14V often and has never let me down. But I also have one of the cigar lighter "meters"
post Jan 6 2026, 06:36 AM
It's really not the voltmeter, I checked mine against a nice multimeter and it shows pretty dead on to that. The problem is where it is tapped into the system. Unless you run a direct wire from the volt meter to the battery you really only have another method of knowing your brake light is working.
I put a relay inline using the original wiring of the volt meter to trigger it. I have fused wire running from the relay to the battery and to the relay -> volt meter. The volt meter is now key activated (using the original wiring) and it only tells me what the battery is seeing. I went from a situation you describe to a nice steady 13.8.
I also use a digital adjustable voltage regulator and highly recommend them. Cheap, sturdy, and fits the slot.
GregAmy
post Jan 6 2026, 08:15 AM
QUOTE(SKL1 @ Jan 5 2026, 10:52 PM) *
It's not. Measure the voltage at the battery while the engine is running.
My voltmeter gave me enough scares - usually while well away from home - that I just removed the whole center console to give my 6'1" frame a bit more legroom. The idiot lights and fuel gauge-installed oil temp keep me honest.
I did add some extra LEDs to catch my attention, though. - GA
SKL1
post Jan 6 2026, 11:47 AM
Thanks. The meter in the lighter sounds great but I took the lighter out some 40 years ago and replaced it with an oil temp gauge.
I'll measure at the battery and see what gives...
- Lo-Fi Version Time is now: 7th January 2026 - 07:16 PM
